Page 1 of 3 1 2 3
'71 318-four speeds in an e-body possible? #1169172
01/31/12 03:05 AM
01/31/12 03:05 AM
NotRussia
2
2fast4yourBrain Offline OP
Whack top Dodger
Whack top Dodger
2
NotRussia
Ola's e-body 'vert registry lists 6 318 4-speed Barracudas, including one with a shaker.
Is it possible to have such an engine/trans combo in 1971? I just flat out don't believe the 318 shaker car.
BH27G1B 189799 A20 TU 4 sp U x722x GY3 H6XW V3W B51,C16,C55,G36,P37,R11
BH27G1B 388298 5xx 4 sp ? x722x EV2 H6X9 V3X
BH27G1B 390008 513 SA 4 sp U x722x GB5 H6XW V3W A01,A36,B51,C16,C55,G37,H51,J45,J54,M21,P31,P37,R21,26
BH27G1B 426254 611 FR 4 sp U x722x GY3 H6X9 V3X C55,Rxx
BH27G1B 4 sp ? x722x GY3 H6X9 V3X V6X A01,A22,G36,J25,J45,J81,L34,M25,M31,M88,N41,N42,N96,Rxx
Then there's also 3 Challenger 318s w/4-speeds:
JH27G1B 154809 924 TH 4 sp ? x2165x FC7 H6XW V3W V5W C16,C55,G36,H51,M31,P37,Rxx,26
JH27G1B 156875 9xx 25 or 26 4 sp U x1793x FE5 H6X9 V3X A62,G33,N85,P37
JH27G1B 238789 C09 TU 4 sp U x1793x TX9 H6X9 V3X V5X A46,C55,G15,G31,G33,L31,M31,M42,M44,P37,R11
Re: '71 318-four speeds in an e-body possible? [Re: 2fast4yourBrain] #1169173
01/31/12 03:45 AM
01/31/12 03:45 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Yes, 1971 & 318 & 4-spd is possible in a Barracuda convertible - the '71 production numbers are a bit messed up, but in '70 ~58 were built (US spec.). The lack of a VIN# on the one with the N96 would lead me to believe that those are visual clues to ID it if further info became available.
Here's a '70 Barracuda convertible factory pink, 318, 4-spd, A/C, & AM/FM.
pic "stolen" from pantherpink.com
Re: '71 318-four speeds in an e-body possible? [Re: 6bblgt] #1169174
01/31/12 01:51 PM
01/31/12 01:51 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
I was specifically referring to 1971s.
According to:
http://home.earthlink.net/~mopared/productionchange.htm
"8/20/70: Code D21, 4-speed transmission, is not available with 198, 225, 318 or 383-2v engines. "
I guess there could have been a few 1971 four-speed 318s squeek through before that date.
Re: '71 318-four speeds in an e-body possible? [Re: 2fast4yourBrain] #1169175
01/31/12 02:21 PM
01/31/12 02:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Seen my share of E body 318 4 spds over the decades, parted a few, including a vert,....but a "SHAKER" 318?,...dealer install possible, factory? ....not buying that
Re: '71 318-four speeds in an e-body possible? [Re: DAYCLONA] #1169176
01/31/12 03:12 PM
01/31/12 03:12 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
a shaker on a 318 would have to be a one off base plate to fit a 2 barrel. and if they would have had a 318 4 bbl (not optional), more than likely it was dealer installed.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: '71 318-four speeds in an e-body possible? [Re: mopars_1] #1169177
01/31/12 03:17 PM
01/31/12 03:17 PM
Salem, OH (Quaker City Raceway...
GuruRanger Offline
GuruRanger  Offline
Re: '71 318-four speeds in an e-body possible? [Re: GuruRanger] #1169178
01/31/12 05:11 PM
01/31/12 05:11 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
How does it ( N96 ) get on the fender tag if it was dealer installed???
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: '71 318-four speeds in an e-body possible? [Re: fireeng] #1169179
01/31/12 06:10 PM
01/31/12 06:10 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
show me a factory shaker 2 barrel base plate and Ill believe the car is real
1937 Plymouth PT50
Re: '71 318-four speeds in an e-body possible? [Re: 6bblgt] #1169180
01/31/12 06:18 PM
01/31/12 06:18 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Re: '71 318-four speeds in an e-body possible? [Re: 6bblgt] #1169181
01/31/12 06:24 PM
01/31/12 06:24 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Ya, should ask Ola how that car got in his registry.
Note the V6X on there too.
Re: '71 318-four speeds in an e-body possible? [Re: 2fast4yourBrain] #1169182
01/31/12 06:50 PM
01/31/12 06:50 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
As well as hood pins, road lamps, rear spoiler, & dual exhaust w/ bright tips.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: '71 318-four speeds in an e-body possible? [Re: I_bleed_MOPAR] #1169183
01/31/12 07:11 PM
01/31/12 07:11 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
Tim
That is ...... or would of been one nicely dressed 318.
Can anyone tell me if the 318 rallye challengers or cudas in 73 and 74 came with duel exhaust and/or four barrels?
1971 Challenger
2013 Jeep Wrangler
Re: '71 318-four speeds in an e-body possible? [Re: fireeng] #1169184
01/31/12 07:15 PM
01/31/12 07:15 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
NO factory dual exhaust or 4bbl on 318 powered e-bodies.
IIRC, LA318 didn't get a 4bbl until 1978.
Re: '71 318-four speeds in an e-body possible? [Re: 6bblgt] #1169185
01/31/12 07:41 PM
01/31/12 07:41 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
I believe my 71 318 was built sept 22, 1970. My vin is jh23g1b150402, does this mean I have the 402nd challenger built at hamtramck?
1971 Challenger
2013 Jeep Wrangler
Re: '71 318-four speeds in an e-body possible? [Re: 2fast4yourBrain] #1169186
01/31/12 08:02 PM
01/31/12 08:02 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
All of the E44/D21's I have are after that date. I think that source may be inaccurate.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: '71 318-four speeds in an e-body possible? [Re: fireeng] #1169187
01/31/12 08:04 PM
01/31/12 08:04 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
No...it means your car had the 50,402nd VIN assigned to all cars built at the plant. With only a couple of exceptions, VINs were not assigned sequentially by makes and/or models.
Seeking:
Re: '71 318-four speeds in an e-body possible? [Re: 69CoronetRT] #1169188
02/01/12 07:54 AM
02/01/12 07:54 AM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
Thanks for the explanation. Sorry for the hijack.
1971 Challenger
2013 Jeep Wrangler
Re: '71 318-four speeds in an e-body possible? [Re: fireeng] #1169189
02/01/12 12:51 PM
02/01/12 12:51 PM
Clarkston,MI
Todd_DesMarais Offline
super street
super street
Clarkston,MI
"Can anyone tell me if the 318 rallye challengers or cudas in 73 and 74 came with duel exhaust and/or four barrels?
This is a great question as my car is a true 318 'Cuda (BS23G4B14xxxx) but the trunk pan has the single tip hanger and no evidence of a second pipe. Kinda hard to imagine a real 'Cuda with a non 'Cuda valence panel.
BTW, mine was a yellow/blk top 318/904, A/C, rear swaybar, console, non-ralley car. Now it's a hulk of metal & parts waiting patiently in the corner.
Todd
aduC' 47 IIeredevleB 66 383 etilletaS 66 DTC 0053 MAR 50 "ssenlli latnem a dna ,ybboh a neewteb enil enif a si ereht"
Re: '71 318-four speeds in an e-body possible? [Re: Todd_DesMarais] #1169190
02/01/12 02:50 PM
02/01/12 02:50 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The standard engine for the Cuda was a 318. No four barrel or dual exhaust were ever offered on a 318 E-body.
I guess I don't know what you mean by non-rallye when talking about a Cuda? Do you mean non-rallye dash? The Rallye dash was standard in a Rallye Challenger but optional in the Cuda.
Re: '71 318-four speeds in an e-body possible? [Re: burdar] #1169191
02/01/12 07:02 PM
02/01/12 07:02 PM
La Verne, CA
lakerism Offline
lakerism  Offline
La Verne, CA
Um, the standard enging for a 'Cuda was NOT a 318 It was a 383 318 IS standard on the Barracuda
Page 1 of 3 1 2 3
