'71 318-four speeds in an e-body possible?
#1169172
01/31/12 02:05 AM
01/31/12 02:05 AM
Posts: 6,111 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
Ola's e-body 'vert registry lists 6 318 4-speed Barracudas, including one with a shaker.
Is it possible to have such an engine/trans combo in 1971? I just flat out don't believe the 318 shaker car.
BH27G1B 189799 A20 TU 4 sp U x722x GY3 H6XW V3W B51,C16,C55,G36,P37,R11
BH27G1B 388298 5xx 4 sp ? x722x EV2 H6X9 V3X BH27G1B 390008 513 SA 4 sp U x722x GB5 H6XW V3W A01,A36,B51,C16,C55,G37,H51,J45,J54,M21,P31,P37,R21,26
BH27G1B 426254 611 FR 4 sp U x722x GY3 H6X9 V3X C55,Rxx
BH27G1B 4 sp ? x722x GY3 H6X9 V3X V6X A01,A22,G36,J25,J45,J81,L34,M25,M31,M88,N41,N42,N96,Rxx
Then there's also 3 Challenger 318s w/4-speeds:
JH27G1B 154809 924 TH 4 sp ? x2165x FC7 H6XW V3W V5W C16,C55,G36,H51,M31,P37,Rxx,26
JH27G1B 156875 9xx 25 or 26 4 sp U x1793x FE5 H6X9 V3X A62,G33,N85,P37
JH27G1B 238789 C09 TU 4 sp U x1793x TX9 H6X9 V3X V5X A46,C55,G15,G31,G33,L31,M31,M42,M44,P37,R11
Re: '71 318-four speeds in an e-body possible?
[Re: 2fast4yourBrain]
#1169173
01/31/12 02:45 AM
01/31/12 02:45 AM
Posts: 17,561 Las Vegas, NV
6bblgt
Las Vegas, NV
Yes, 1971 & 318 & 4-spd is possible in a Barracuda convertible - the '71 production numbers are a bit messed up, but in '70 ~58 were built (US spec.). The lack of a VIN# on the one with the N96 would lead me to believe that those are visual clues to ID it if further info became available. Here's a '70 Barracuda convertible factory pink, 318, 4-spd, A/C, & AM/FM. pic "stolen" from pantherpink.com
[Re: 6bblgt]
#1169174
01/31/12 12:51 PM
01/31/12 12:51 PM
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
I was specifically referring to 1971s. According to: http://home.earthlink.net/~mopared/productionchange.htm"8/20/70: Code D21, 4-speed transmission, is not available with 198, 225, 318 or 383-2v engines. " I guess there could have been a few 1971 four-speed 318s squeek through before that date.
[Re: DAYCLONA]
#1169176
01/31/12 02:12 PM
01/31/12 02:12 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
a shaker on a 318 would have to be a one off base plate to fit a 2 barrel. and if they would have had a 318 4 bbl (not optional), more than likely it was dealer installed.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: GuruRanger]
#1169178
01/31/12 04:11 PM
01/31/12 04:11 PM
Posts: 915 near New Haven, CT
fireeng
near New Haven, CT
How does it ( N96 ) get on the fender tag if it was dealer installed???
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
[Re: 6bblgt]
#1169180
01/31/12 05:18 PM
01/31/12 05:18 PM
6bblgt
Las Vegas, NV
[Re: 6bblgt]
#1169185
01/31/12 06:41 PM
01/31/12 06:41 PM
fireeng
near New Haven, CT
I believe my 71 318 was built sept 22, 1970. My vin is jh23g1b150402, does this mean I have the 402nd challenger built at hamtramck?
#1169186
01/31/12 07:02 PM
01/31/12 07:02 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
All of the E44/D21's I have are after that date. I think that source may be inaccurate.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: fireeng]
#1169187
01/31/12 07:04 PM
01/31/12 07:04 PM
69CoronetRT
Harlan, Iowa
No...it means your car had the 50,402nd VIN assigned to all cars built at the plant. With only a couple of exceptions, VINs were not assigned sequentially by makes and/or models.
Seeking:
[Re: 69CoronetRT]
#1169188
02/01/12 06:54 AM
02/01/12 06:54 AM
fireeng
near New Haven, CT
Thanks for the explanation. Sorry for the hijack.
[Re: fireeng]
#1169189
02/01/12 11:51 AM
02/01/12 11:51 AM
Posts: 477 Clarkston,MI
Todd_DesMarais
super street
super street
Clarkston,MI
"Can anyone tell me if the 318 rallye challengers or cudas in 73 and 74 came with duel exhaust and/or four barrels? " This is a great question as my car is a true 318 'Cuda (BS23G4B14xxxx) but the trunk pan has the single tip hanger and no evidence of a second pipe. Kinda hard to imagine a real 'Cuda with a non 'Cuda valence panel. BTW, mine was a yellow/blk top 318/904, A/C, rear swaybar, console, non-ralley car. Now it's a hulk of metal & parts waiting patiently in the corner. Todd
aduC' 47
IIeredevleB 66
383 etilletaS 66
DTC 0053 MAR 50
"ssenlli latnem a dna ,ybboh a neewteb enil enif a si ereht"
[Re: dogdays]
#1169197
02/08/12 12:35 PM
02/08/12 12:35 PM
Todd_DesMarais
super street
super street
Clarkston,MI
By "non-ralley" I meant the instrumant cluster.
The only available options mine didn't come with are; fender mounted turn indicators, ralley dash, am/fm w/cassette, hood pins, and the aformentioned 360 w/dual exhaust. Also, my car is not a Barracuda nor a Gran Coupe, it is a BS23 'Cuda and had the 318/904 combo.
From what I have researched, in '73 the BS23 'Cuda came with a 318 2bbl standard and a 340 4bbl option. in '74 it was a 318 2bbl standard and 360 4bbl option. I have never seen nor heard of a '73-4 318 manual trans 'Cuda and neither Galen or his books could tell me if any exist.
Still hard to imagine a loaded, badged out 'Cuda with a single pipe !
aduC' 47
IIeredevleB 66
383 etilletaS 66
DTC 0053 MAR 50
[Re: Todd_DesMarais]
#1169198
02/08/12 03:52 PM
02/08/12 03:52 PM
Posts: 4,361 St. Louis, Mo
318 Stroker
St. Louis, Mo
Hood pins were not available on the 73 E-bodies.
As for the trans, you could get a 318 2 bbl, single exhaust and it came with a 3-spd floor-mounted manual. 4-spd not available with the 318 in 73. Torqueflite was optional.
On E-bodies, 4-spd was only available on the 340 in 73, 360 in 74.
[Re: MN-ScatPack]
#1169201
02/08/12 09:57 PM
02/08/12 09:57 PM
Posts: 7,392 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I think the 340 was standard in the 72 Cuda very early on in production. I think there is some factory literature on Hamtramck-historical stating that the 318 would be the standard engine in the 72 Cuda after a certain date. I'd have to look for it to be certain. EDIT: Here is the bulletin dated Sept 24, 1971. http://www.hamtramck-historical.com/imag...p%20pib%205.jpg
#1169203
02/09/12 06:29 PM
02/09/12 06:29 PM
318 Stroker
St. Louis, Mo
Were hood pins available on a '74 BS23G (318) 'Cuda and if so, was the "Plymouth" nameplate still in the front corner ? I have an earlier hoodpin hood that has no notches in the brace for the three studs to mount the nameplate (I assume so the lanyard doesn't rub on it) and a later non-hoodpin hood that has them. Either way, it will have pins and dual exhaust if/when I ever get to finish it.
Hood pins were not offered on any 72-74 E-bodies. As far as putting them on your 73 Cuda, go for it... I put them on my 73 Challenger, and like them alot. I also put on the duals w/ factory tips.
#2133141
08/14/16 11:11 PM
08/14/16 11:11 PM
Posts: 23 Ontario, Canada
MooVstunts
Ontario, Canada
It appears the 3rd one on the list: BH27G1B 390008 513 SA 4 sp U x722x GB5 H6XW V3W A01,A36,B51,C16,C55,G37,H51,J45,J54,M21,P31,P37,R21,26 is up for sale on ebey... ebay link to 1971 Barracuda Convertible 318 car
[Re: GuruRanger]
#2134079
08/16/16 12:56 AM
08/16/16 12:56 AM
Posts: 1,900 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Not to hijack the E-body thread..but I have the sister car to your 'Runner a '74 Charger Rallye with a 318-2bbl and a console shifted pistol grip 4-speed. I'm sure it's rare too! ~RT NO factory dual exhaust or 4bbl on 318 powered e-bodies.
That's interesting, I never knew that the later 'Cuda was offered with a 318 2V with no dual exhaust with it. Yet you could get a 318 2V Road Runner in '73-'74 and it came with dual exhaust and machine gun tips. <img src="/ubbthreads/images/graemlins/shruggy.gif" alt="" /> I have a '73 Road Runner, factory 318 2V, Pistolgrip 4 speed car (rarest combo that year, 1 of 350) with dual exhaust and tips:
[Re: dogdays]
#2134371
08/16/16 01:41 PM
08/16/16 01:41 PM
Posts: 12,535 Kalispell Mt.
HotRodDave
Kalispell Mt.
For the uninformed, the base level Plymouth E-body was called Barracuda. The high performance one was called 'Cuda and the luxury one was called Gran Coupe. The 'Cuda was the counterpart of the Challenger R/T.
So many people call every Plymouth E-body a 'Cuda but that's not accurate.
R. The public was calling all barracudas "cudas" long before plymouth did their performance barracuda.
#2134391
08/16/16 02:12 PM
08/16/16 02:12 PM
Posts: 16,218 Mesa, Arizona
dart4forte
Mesa, Arizona
I know a guy that has two RRs 73/74 318, 2 barrel duel exhaust with tips. One is a 4 speed
Abe Lincoln
[Re: 6bblgt]
#2134572
08/16/16 06:36 PM
08/16/16 06:36 PM
MooVstunts
Ontario, Canada
that is NOT a Chrysler Corp. produced fender tag I totally thought the tag was too good to be true... but what is the "tell?"
#2134573
08/16/16 06:37 PM
08/16/16 06:37 PM
MooVstunts
Ontario, Canada
Tag from the Craigslist Convertible...
First time I've seen V5B (plenty of V5X).
[Re: joelson6]
#2135100
08/17/16 12:52 PM
08/17/16 12:52 PM
Posts: 1,822 Colorado
denfireguy
Colorado
VIN number in ad is incorrect. There is a number where the engine letter should be. BTW, this was a 4 year old thread that got resurrected. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#2135259
08/17/16 05:09 PM
08/17/16 05:09 PM
6bblgt
Las Vegas, NV
VIN number in ad is incorrect. There is a number where the engine letter should be. BTW, this was a 4 year old thread that got resurrected. Craig true - because one of the original cars (BH27G1B390008) that the thread was started about was recently listed on eBay.
