What is this...Speedo cable adapter???
#1169108
01/31/12 01:28 AM
01/31/12 01:28 AM
Posts: 3,344 Central TX
roe
Central TX
71 Satellite 360/904. Trying to get my speedo working, it used to work intermittently and I would have to press it in at the connection behind the dash. Then it went out completely and now doesnt work at all. So I ordered a new one and after removing the old one, I saw that the plastic clip that attacheds behind the dash is broken, and the new speedo that is for a 71' satellite doesn't fit at the trans connection because, Oops, I forgot that I found out that the trans is and '84 A-904, panrail numbers are PK4295887 8561 2973. So I took the new plastic clip and transferred it to my previous cable, lubed and reinstalled it, then hooked it all back up. Still doesn't work. Then I go down to the trans and take a closer look at this thing you see in the pics below. What is it. I also found that the part of this thing that screws into the trans broke off. Thats it that you see lying beside it, and the next pic shows where it broke off at. So I fished it out and hooked my speedo cable directly to trans instead of through this thing, still doesn't work, as I expected. So, my questions are: 1. What exactly is this thing. 2. Do I have to have this thing hooked up? If so where do I find it, what do I look it up as? 3. What car do I order a speedo cable for in order to get this thing working. Thanks roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
Re: What is this...Speedo cable adapter???
[Re: roe]
#1169109
01/31/12 02:14 PM
01/31/12 02:14 PM
roe
Central TX
Anyone? I really need some help. I don't know what it is and can't find anything kilobit they the parts stores. Also it has an electrical connector that comes offing it and plugs into the wiring down by the Trans.
[Re: Andrewh]
#1169113
01/31/12 05:31 PM
01/31/12 05:31 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Correct, it's a centrifugal switch that supplies a ground at 40 mph...used on some '71 and later NOX systems.
[Re: Andrewh]
#1169115
01/31/12 08:24 PM
01/31/12 08:24 PM
roe
Central TX
pretty sure that was an emissions or somehting like that adapter. gave a ground signal at like 35 mph. people have been collecting them for the od transmissions.
Going by the numbers on my panrail, this is not an overdrive unit right? Because overdrive units are bigger and require floorpan mods, which my cars floorboards are untouched. Unless there is a factory swap to an overdrive unit that I dont know about that doesn't require surgery.
What do they do for the overdrive units?
[Re: roe]
#1169116
01/31/12 08:38 PM
01/31/12 08:38 PM
Andrewh
no it is not an od unit in your car. it was used for emmisions in your car.
the people putting in od units use it to tell the od trans when it can use the od vs having to put in a toggle switch. since it will let them know when it is moving fast enough.
[Re: Andrewh]
#1169117
01/31/12 08:45 PM
01/31/12 08:45 PM
roe
Central TX
I pretty much know it wasnt overdrive, but figured it was worth checking as guys on here have way more knowledge on this stuff than I do. Can't know for sure until you ask right? Anyway, I guess I'll just hit the parts store and troll around until I find something thats long enough and has the right size "nut" at the trans connection. We'll see. Thanks again everyone roe
[Re: Challenger 1]
#1169119
02/01/12 02:35 AM
02/01/12 02:35 AM
roe
Central TX
Well, I have my speedo working now. I went and trolled around two parts stores until I found something useful. I found one that was the right length and had the right size connecter at the trans, but it had the wrong connector for the dash, part# 03153 at Advance Auto Parts for $10. So I took that home and made a speedo cable with the casing and cable from the new one, and the dash connector from the old one. Then I had to disassemble and lube it, and cut the new casing down about 1" in order to get the cable to stick out far enough to engage the dash and the trans. Reads fairly accurate too. Seems to be within about 3-4 mph of the GPS speed, and sometimes it seemed t be dead on. I have to get used to reading the speedo again, and it could be even more accurate than I thought because I was trying to drive, and watch the speedo and GPS at the same time.
roe
[Re: roe]
#1169120
02/01/12 12:05 PM
02/01/12 12:05 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Glad you got it figured out. I was going to suggest finding the part with the gear, that goes into the trans from a 71 and putting it in your trans. They do interchange don't they?
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1169121
02/01/12 05:14 PM
02/01/12 05:14 PM
roe
Central TX
I didn't know that was an option. Looking at it though, I would think it should work.
