carb size
#1168895
01/30/12 07:10 PM
01/30/12 07:10 PM
Posts: 582 Dayton, OH
1980volare
My man card has just been revoked.
Dayton, OH
ok heres the rundown. i have a 600 eddy and wonder if i can benefit from the same sized holley, or a larger cfm model.
83 318 magnum head swap summit 6900 cam headers m1 dual plane intake 2.5" x pipe exhaust
ive heard storys of people noticing large differences in power levels from going from eddys to holleys. is it worth a shot?
any input is appreciated.
Re: carb size
[Re: 1980volare]
#1168903
02/01/12 02:04 PM
02/01/12 02:04 PM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
I'm thinking of purchasing a new 600, 650, or 750. I'm still thinking a 750 might be a tad large
http://www.jegs.com/i/Quick-Fuel/793/SL750VS/10002/-1
If you decide to run that carb on a 318 prepare to buy some jets and air bleeds (or find someone that has some you can try) to dial in the carb. I ended up having to do a bit of work to get one running on a stock 440. Not a bad carb, but will need a bit of calibration to get it right. I also had to change the spring in the vac. secondary diaphragm to slow down the secondary side of the carb (heavy car, highway gear, tight converter).
For a 318 I'd get this instead:
http://www.summitracing.com/parts/QFT-SL-600-VS/
Re: carb size
[Re: 1980volare]
#1168905
02/01/12 04:40 PM
02/01/12 04:40 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Yes by a bunch. The 750 vac holley is one of the best out there out of the box Just seems to work good 318 to 440. I had a 600 eddy then switched to my 750 vacuum on my 318 that had a cam intake and headers in my truck and it was at home there as on my 440. Stock jets and just lighter secondary opening springs for a little faster to the 4 barrel opening (they are slow as shipped) and it would work great on whatever you plunked it on 318, 340, 360, 383/400 440. So if your not up at 2500 feet or more will not need jetting but I do find the 4 barrel opens a little slow for me so buy a spring kit and start in the middle and go lighter stock spring is pretty tight! Do check the float levels holley does not always have them right! I miss that carb was so nice to flop on anything and it would run good when trouble shooting.
