Wiper arm Removal #1168861
01/30/12 06:06 PM
01/30/12 06:06 PM
Iowa
Marc Challenger Offline OP
Iowa
Help Please. Can someone tell me how to release the wiper arms from the posts on a 71 Challenger? I am assuning that the release is the spring loaded U shaped "wire" at the very base of the arm, but I couldn't figure it out. They have been on for some time. Do I need a tool?
Re: Wiper arm Removal [Re: Marc Challenger] #1168862
01/30/12 07:02 PM
01/30/12 07:02 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Yes you need push the little tab, I wrap them with a rag and grap them with vice grips and wiggle and pull. They will come off but it takes some muscle.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Wiper arm Removal [Re: HemiRick] #1168863
01/30/12 09:42 PM
01/30/12 09:42 PM
Iowa
Iowa
I appreciate the reply, I'm learning as I go. When you say push the tab, are you saying push it up, down, towards the post or away?
Thanks again.
Re: Wiper arm Removal [Re: Marc Challenger] #1168864
01/30/12 10:09 PM
01/30/12 10:09 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Away from post, also try a little lube like WD40, CRC, Gibbs, etc. While pulling back on clip pry the arm up with care not to damage what you are prying on.
Re: Wiper arm Removal [Re: Marc Challenger] #1168865
01/30/12 10:45 PM
01/30/12 10:45 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here is what you are working with if a '71 Challenger wiper arm is the same as a '69 GTX?
MikeR
Re: Wiper arm Removal [Re: A12] #1168866
01/30/12 10:46 PM
01/30/12 10:46 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
2
Re: Wiper arm Removal [Re: A12] #1168867
01/30/12 10:47 PM
01/30/12 10:47 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
3
Re: Wiper arm Removal [Re: A12] #1168868
01/30/12 10:54 PM
01/30/12 10:54 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
So you move the clip back away from the post and pull or pry up the wiper blade assembly. I used a small block of wood and a tape wrapped large screwdriver and a triple folded shop rag. I wanted to use some WD40 or similar but was concerned about the black hood stripe finish on the GTX.........came off without any lube but I did put them back on with a little anti-seize compound
Re: Wiper arm Removal [Re: A12] #1168869
01/31/12 12:44 AM
01/31/12 12:44 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
This is one of the best (and cheapest) tools I have ever bought. You need one, trust me.
http://buy1.snapon.com/catalog/item.asp?store=snapon-store&item_ID=12787&group_ID=1785
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Wiper arm Removal [Re: 5wndwcpe] #1168870
01/31/12 05:27 PM
01/31/12 05:27 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I bought a Lisle #65750 from a tool vendor at a car show a couple of weeks ago for 4 bucks,works fine.
Google Lisle Tools. Not Snap-on,but it was made in the USA.
Re: Wiper arm Removal [Re: pushbutton] #1168871
02/01/12 01:45 PM
02/01/12 01:45 PM
Iowa
Iowa
Thanks everybody, I appreciate the help
Re: Wiper arm Removal [Re: 5wndwcpe] #1168872
02/02/12 04:03 AM
02/02/12 04:03 AM
cataclysm80 Offline
cataclysm80  Offline
can be done without it, but if you're gonna need to do this more than once, that tool looks handy. Thanks!
I think I've had wiper arms off at least 4 different vehicles. That tool probably would have saved me a lot of time and hassle. I've also been going the cloth/wood block/screwdrivers route.
Tav
Re: Wiper arm Removal [Re: cataclysm80] #1168873
02/02/12 12:29 PM
02/02/12 12:29 PM
Montgomery, Alabama
RusTy/SE Offline
RusTy/SE  Offline
Montgomery, Alabama
I'm away from my home pc but here's the link to what I posted on ramchargercentral showing the steps taken to remove the wiper arms, then remove and replace the linkage bushings on my 86 D250.
http://ramchargercentral.com/index.php?p...di83atn93v00852
It may be more than you need but consider it another option
Russ
