Engine should die, right? #1168289
01/30/12 12:36 AM
01/30/12 12:36 AM
Scottsdale, AZ
K
kenz Offline OP
kenz  Offline OP
K
Scottsdale, AZ
If you cover the carb on a running engine, it should die, right? The 318 in our 73 Duster will keep running when we cover the carb with a cloth. 2
We've been having problems getting it running correctly. It's a rebuilt engine with a new Edelbrock carb and manifold. We've tried 2 different manifolds and 2 different carbs, all new. We've tried spraying carb cleaner all over the carb and manifold while running and it has no effect. So where is it getting air from?
Any ideas?
Thanks,
Ken
Mopars Unlimited of Arizona
www.moparsaz.com
Re: Engine should die, right? [Re: kenz] #1168290
01/30/12 12:38 AM
01/30/12 12:38 AM
Scottsdale, AZ
K
kenz Offline OP
kenz  Offline OP
K
Scottsdale, AZ
I just realized I posted this in the wrong forum. Could a moderator move it?
sorry.
Re: Engine should die, right? [Re: kenz] #1168291
01/30/12 01:09 AM
01/30/12 01:09 AM
More detailed info: when did it start, any part changes preceding it acting up, was it right at one time. You're in the right forum unless you're saying you had a prior thread on this somewhere else & I doubt if the mods will move it, we'll fix it for you!
Re: Engine should die, right? [Re: RapidRobert] #1168292
01/30/12 01:23 AM
01/30/12 01:23 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
big vacum leak
Re: Engine should die, right? [Re: 05dakota] #1168293
01/30/12 01:39 AM
01/30/12 01:39 AM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Cracked/leaking PCV hose?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Engine should die, right? [Re: Secret Chimp] #1168294
01/30/12 01:55 AM
01/30/12 01:55 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Possible bad brake booster. Disconnect ALL external vacuum lines, including vacuum advance and plug the sources......
Re: Engine should die, right? [Re: 05dakota] #1168295
01/30/12 06:13 PM
01/30/12 06:13 PM
Surface of the SUN
N
newvcode Offline
newvcode  Offline
N
Surface of the SUN
big vacum leak
No doubt!!! Also check throttle plates and rod bushings... shoot some WD40 in the bushing sides if it revs.... they're toast.
Re: Engine should die, right? [Re: kenz] #1168296
01/30/12 06:25 PM
01/30/12 06:25 PM
Change the intake gaskets & get the composition ones & use Permatex "high tack" the red stuff in a spray can & use a thick/wide carefully placed swath of clear silicone on the front/rear rails in place of the gaskets letting it sit up overnight as the supplied front/rear gaskets can be too thick but if a massive vac leak it'd have to be an intake/head interface gasket/alignment prob I'd think
Re: Engine should die, right? [Re: RapidRobert] #1168297
01/30/12 09:41 PM
01/30/12 09:41 PM
Scottsdale, AZ
K
kenz Offline OP
kenz  Offline OP
K
Scottsdale, AZ
The engine has never run correctly. We bought a rebuilt long block and have been trying to get it running. Here's what has been done so far.
1- Started with a new Edelbrock Performer manifold and 600 cfm carb.
2- Changed the carb to a new Edelbrock 650 cfm
3- Changed manifold to a new Weiand Action Plus
Intake gaskets are Fel-Pro composite with a light coating of RTV and RTV on the end rails. Throughout all of this all vacuum lines are disconnected and plugged. We've sprayed carb cleaner all over the carb and manifold while the engine is running after each change. There is no change in the idle so I can't see how it's pulling air from outside the engine.
I suspect an intake manifold to head mismatch but since we've tried 2 different brand new manifolds I'm beginning to think there is something wrong with one or both heads. There's nothing else it could be, is there?
Thanks,
Ken
www.moparsaz.com
Re: Engine should die, right? [Re: kenz] #1168298
01/30/12 09:46 PM
01/30/12 09:46 PM
Western PA
O
OldMoparMan Offline
OldMoparMan  Offline
O
Western PA
Does it have an EGR valve or similar smog valve if so check it or plug the lines off and try running the engine
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: Engine should die, right? [Re: kenz] #1168299
01/30/12 10:21 PM
01/30/12 10:21 PM
Might switch gears & check true TDC on the dampener & dont remem if you mentioned what it is timed at. rotor phasing acceptable. EGR closed. Kind of WAG ing here. I enjoy 318's, wish I was closer to give you a hand
Re: Engine should die, right? [Re: RapidRobert] #1168300
01/30/12 10:36 PM
01/30/12 10:36 PM
Scottsdale, AZ
K
kenz Offline OP
kenz  Offline OP
K
Scottsdale, AZ
We verified tdc and degreed the cam to make sure everything was correct. Plus it was a good learning experience for my son. :-)
The timing is set at 18 degrees btdc.
There is no egr.
Not sure about rotor phasing but I forgot to mention that we tried both a rebuilt stock distributor and a MP unit. Made no difference.
We've spent so much trying new parts that I guess we should have just bought a crate motor. :-(
Thanks again for the help.
Ken
www.moparsaz.com
Re: Engine should die, right? [Re: kenz] #1168301
01/30/12 10:42 PM
01/30/12 10:42 PM
Sure is pointing to a vac leak. We're gonna laugh when we find it
Re: Engine should die, right? [Re: kenz] #1168302
01/31/12 09:10 PM
01/31/12 09:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
CLOTH? gonna keep running. The cloth is essentially an air filter.
Don't be the exception.
Re: Engine should die, right? [Re: Supercuda] #1168303
01/31/12 10:06 PM
01/31/12 10:06 PM
Scottsdale, AZ
K
kenz Offline OP
kenz  Offline OP
K
Scottsdale, AZ
I used a shop rag with my hands over it just to be sure. I'm fairly certain no air was getting into the top of the carb. :-)
www.moparsaz.com
