Clean a aluminum intake with no bead blasting.!
#1167815
01/29/12 04:34 PM
01/29/12 04:34 PM
Posts: 768 Maryville tn
67coronetman
Maryville tn
I have a mopar M-1 intake that i just port matched & was wondering what some of you used out here to clean it & make it look nice again. I really don't ant to bead blast it if someone has used a product that really works good.
Old car are me......
Re: Clean a aluminum intake with no bead blasting.!
[Re: 67coronetman]
#1167816
01/29/12 04:43 PM
01/29/12 04:43 PM
Posts: 819 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I used Simple Green barbecue cleaner and a nylon cup brush on my drill. Simple Green and a high-pressure rinse really gets a lot of stuff off with not a whole lot of effort.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: 67coronetman]
#1167824
01/30/12 12:48 AM
01/30/12 12:48 AM
RapidRobert
Might be too picky but I'd tape up the ports/flange if glassbeading to keep the beads from possible embedding in inside crevices then heat releasing them later on
[Re: JohnRR]
#1167826
01/31/12 12:58 PM
01/31/12 12:58 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Eagle One mag wheel cleaner if you can still get it.
This was what I used , bought it within the last 6 months at Advanced auto .
I bought some yesterday morning....for a few manifolds I got from the swap meet.
Not as strong as it used to be from ages ago (but what is here in CA anymore) but still has abit of bite to it and cleaned them ok.
[Re: Mr.Yuck]
#1167829
02/01/12 04:43 PM
02/01/12 04:43 PM
Posts: 8,859 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
How about this intake? was pretty dirty looked like was left in a barn for years i took it to a monument place let them blast it i had all ports duct taped up nice brung home took air hose to it then painted it with some metalic gray/silver the last coat i held back bout a foot and half to give a over spray effect it looks like i took it stright out of the box
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#1167830
02/01/12 04:58 PM
02/01/12 04:58 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Differnt intake i did same way
