Re: SIX PACK WON'T IDLE
[Re: ThermoQuad]
#116748
10/20/08 11:49 AM
10/20/08 11:49 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Everyone with "6 pk problems"
Please would you advance the intial timing to 18 degrees and don't forget the distributor curve rework. And then would you open the outboard adj mixture screws at least 1 turn out?
You have to make these adjustments or it will not run right. We are not kidding just go do it and then finish the rest. This is not k mart, it will not run out of the box
I dont even have to read the rest of the post...lol... Thanks Tom ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: moper]
#116749
10/20/08 06:13 PM
10/20/08 06:13 PM
WELL I TRIED THE 18 DEG AND ALL THE REST BUT THEN I HAD NO IDLE ADJ ON THE CENTER CARB AND THE THING REALLY PINGED EVEN WITH 100 OCT. GAS ANY OTHER INPUT
THANKS MOPARTS
#116750
10/20/08 09:05 PM
10/20/08 09:05 PM
moper
Columbia, CT
rr, please take off the caps lock on your PC... It makes it easier to read. The reason it pinged is you had too much total advance. You can't just dial in initial and expect things to magically work. It's all a system.
So, you need to limit the mechanical advance to less than 20. Tell me what kind of distributor you have and we can fix that. Once the timing curve is properly set, the jetting can be addressed because it's probably lean as heck and that makes it ping too.
If the carb does not respond, there is something interfering, so try this... disconnect the throttle cable from the carb, then try it again. Your idle speed is set witht he center carb alone. But it's fairly common for me to find issues with the cable either being too short because of where its clamped and the carb is held open, or too long because of where its clamped and you dont get full throttle. So check to make sure the throttle can close all the way.
[Re: moper]
#116751
10/21/08 05:26 PM
10/21/08 05:26 PM
Here are my specs. 484 mopar cam 30 over 915 heads with mopar performance dist. with 66 jets in center carb. Vacumn is 10 on idle on manifold port and 5.5 power valve. What do I do to fix it?
thanks
#116752
10/22/08 05:38 PM
10/22/08 05:38 PM
Hey moper where are you ?
