Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS???
[Re: DusterDog]
#1166558
01/30/12 01:37 AM
01/30/12 01:37 AM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
I would be interested in a flat one for my 440 motor. I would not want to have to remove a head to fit it like with the Indy plates.
Would these be a 1, or 2 piece plate??
What price range would these be in??
Can you get a picture when you get one made??
I can make them 1 or 2 piece. If we are trying to seal things up and keep costs down, the 1 piece unit would be the route to go I think.
Here is a short deck version roughly hammered out. The tall deck would be the same, but wider. On this one, I have dropped the center as discussed earlier for dual plane stuff.
Pricing will depend on the material, and the cutting costs. I will have these sorted out before I make them though. Once I have the dimensions solid, the price tag wont be far behind. Thanks.
-Kenny
[Re: mprhound]
#1166576
02/14/12 10:51 PM
02/14/12 10:51 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i know a couple guys that tried running a vac pump from their valley plate with god aweful results
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
