Page 4 of 5 1 2 3 4 5
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: sixpackgut] #1166557
01/29/12 11:09 PM
01/29/12 11:09 PM
Delray beach, Florida
P
Performance Only Offline
P
what is the actual port opening size on the 337. anybody have that handy?
machine shop owner and engine builder
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: DusterDog] #1166558
01/30/12 12:37 AM
01/30/12 12:37 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
I would be interested in a flat one for my 440 motor.
I would not want to have to remove a head to fit it like with the Indy plates.
Would these be a 1, or 2 piece plate??
What price range would these be in??
Can you get a picture when you get one made??
I can make them 1 or 2 piece. If we are trying to seal things up and keep costs down, the 1 piece unit would be the route to go I think.
Here is a short deck version roughly hammered out. The tall deck would be the same, but wider. On this one, I have dropped the center as discussed earlier for dual plane stuff.
Pricing will depend on the material, and the cutting costs. I will have these sorted out before I make them though. Once I have the dimensions solid, the price tag wont be far behind. Thanks.
-Kenny
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166559
01/30/12 12:38 AM
01/30/12 12:38 AM
Alberta Canada
Alberta Canada
top side....
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166560
01/30/12 12:39 AM
01/30/12 12:39 AM
Alberta Canada
Alberta Canada
looking from the front...
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166561
01/30/12 12:41 AM
01/30/12 12:41 AM
Alberta Canada
Alberta Canada
Here is a top view of just the flat plate.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166562
01/30/12 12:42 AM
01/30/12 12:42 AM
Alberta Canada
Alberta Canada
A view with a manifold above it...
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166563
01/30/12 12:43 AM
01/30/12 12:43 AM
Alberta Canada
Alberta Canada
front view again...
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166564
01/30/12 01:40 AM
01/30/12 01:40 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
nice
Tex
New best ET 10.259@129.65 .
New best MPH 130.94
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: tex013] #1166565
01/30/12 02:00 AM
01/30/12 02:00 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
VERRRY NICE! And seeing it in a GOLD hue!...Kenny,you know where this is going! Please try to make this a "reality" before April..when I plan to start putting the ole' 440 back together! BTW...do I get a "Decal Buyer's Discount" on this newfangled valley plate???? I hope so! Keep up the good work,my man!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166566
01/30/12 02:46 AM
01/30/12 02:46 AM
Alberta Canada
Alberta Canada
Haha! Thanks eh! I will try to get to the shop tomorrow to nail down some dimensions.
I think April should be a fairly easy target. I would like to have the first run done soon. What would be ideal for yours Randy, would be to ship it with your decals. As for a discount, we will work something out!
-Kenny
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166567
01/30/12 11:51 AM
01/30/12 11:51 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Kenny,shipping EVERYTHING at once would be ideal! Know ANYONE who needs a USED Indy plate?..excellent shape,fair price! Waiting for the K-1's to arrive this week..then off to get the rotating assembly balanced. Always a GOOD thing to not only go faster...but improve,and STRENGTHEN the bottom-end as well!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166568
01/30/12 12:46 PM
01/30/12 12:46 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
PM Sent
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: roadhazard] #1166569
01/30/12 08:31 PM
01/30/12 08:31 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I trimmed the tin even with the bottom of the port runners and bent the "tabs" under each head and sealed it.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: 64Post] #1166570
01/31/12 01:32 AM
01/31/12 01:32 AM
Alberta Canada
Alberta Canada
I thought about adding a lip that went under the the heads. This would help with sealing. However, this would require the heads to be lifted whenever the valley plate is to be removed. I could maybe make 45 degree angles that bolt to the flat plate. Then the plate could be removable still. This would of course bring the price up, but possibly a better product in the sealing department.
One other thought, would anyone possibly want a screw in breather on the plate? This could be an added option. This would allow you to run valve covers with out breathers to make for a cleaner look. If the breather on the valley plate was in the back, you wouldn't really see it even.
Any other options anyone can think of? I am all ears!
-Kenny
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166571
01/31/12 12:25 PM
01/31/12 12:25 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Kenny..I believe a 45* bevel on the plate-to-head buttment,similar to the Indy design, would be the easiest..and most efficient design for leak-proof sealing! The smaller the gap,the less sealent used= NO OIL LEAKS,OR SEEPING! I would keep it SIMPLE..ONE PIECE..more affordable! As far as the breather incorporated on the plate itself...EXCELLENT IDEA...as long as it's as efficient as valve cover breathers! Real glad you're working on this MUCH-NEEDED piece!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166572
01/31/12 09:33 PM
01/31/12 09:33 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Wouldn't it be difficult to baffle a breather mounted directly in the valley? I would think there is less oil splash/vapor under the valve covers than compared to under the valley plate.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: davenc] #1166573
01/31/12 11:04 PM
01/31/12 11:04 PM
Alberta Canada
Alberta Canada
I think the right breather would do just fine in the valley pan. This could be an option that is an add in if it isn't wanted.
-Kenny
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166574
02/01/12 12:17 PM
02/01/12 12:17 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I guess what style valve covers you have would determine the "need" for the valley plate breather. It would be nice to have that option!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166575
02/14/12 07:55 PM
02/14/12 07:55 PM
Texas
mprhound Offline
mprhound  Offline
Texas
any more on it yet? price? availibility?
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: mprhound] #1166576
02/14/12 09:51 PM
02/14/12 09:51 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i know a couple guys that tried running a vac pump from their valley plate with god aweful results
