Page 1 of 5 1 2 3 4 5
VALLEY PLATE FOR A 440...EDDY RPM HEADS??? #1166497
01/28/12 01:23 AM
01/28/12 01:23 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Has anyone made a GOOD...leak-proof cover yet for this combo? I used an Indy cast plate last season..worked OK...but WAS NOT seep-proof! There is still a larger gap between the heads than is preferred! I know Hughes use to sell a valley cover,but looks to be discontinued,as of lately! Andy F.....any plans to machine,and market one of these in the near future??? Thanks for ANY info on this subject! Randy B.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166498
01/28/12 01:27 AM
01/28/12 01:27 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
use permatex ultra grey silicon
hardends up good no leaks at all
1.39 9.85 - 137 mph
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166499
01/28/12 02:19 AM
01/28/12 02:19 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ended up using the stock tray w/gaskets on both sides and it`s totally dry...............may not look as cool but it works.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Ari440] #1166500
01/28/12 02:45 AM
01/28/12 02:45 AM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
that's what i used. never had a leak. seeya.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: rickraw] #1166501
01/28/12 03:05 AM
01/28/12 03:05 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the tip,Ari! Dom..can't use the stock tin gasket...my heads are cnc-ported!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166502
01/28/12 08:30 AM
01/28/12 08:30 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
You can use tin. It just takes time fittng it.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: BSB67] #1166503
01/28/12 08:57 AM
01/28/12 08:57 AM
tboomer Offline
tboomer  Offline
Randy...I asked the guy doing my heads the same question...He said to take a piece of 1/4" aluminum and make my own. But I do not have any tools to do it so I will be watching this!!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166504
01/28/12 09:49 AM
01/28/12 09:49 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
If you can port the head, you can port the gasket
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Dart1031] #1166505
01/28/12 12:27 PM
01/28/12 12:27 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I've had way too much trouble in the past with the tin valley covers...oil getting "sucked-in" under the gasket! I'd much rather use a plate..and stand-alone composition gaskets..like the Hughes #3266's I just got. They're over-sized to fit ported factory-sized port windows! I trial-fitted one on my Eddy's last night..not much trimming to do at all! Looks like they're going to work well! I'll post a pic of the match shortly! If I can't find a plate with a closer-tolerence fit to the head...I'll just use the Indy plate again!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166506
01/28/12 12:46 PM
01/28/12 12:46 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Well I don't know what you'd do different with 1/4" aluminum than what the Indy cover is but if you wanted to try, all you need is a decent tablesaw and a sharp carbide blade. The blade will go through the aluminum like butter.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166507
01/28/12 12:58 PM
01/28/12 12:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine are a bit bigger than stock so I stacked/glued the gaskets to the tray, bolted em on the head and whittled away. The fit is perfect along w/dry intake runners which is a first.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Thumperdart] #1166508
01/28/12 01:23 PM
01/28/12 01:23 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
It boggles my mind that no one has made a valley cover specifically for these heads! Obviously there is a market for it.
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: cl440] #1166509
01/28/12 01:43 PM
01/28/12 01:43 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
No kiddin' Chuck! I believe Hughes made a couple different styles for this application..but remember hearing complaints of them leaking! I'm surprised Andy F. doesn't manufacture one! There are a LOT of Edelbrock RPM users out there! Andy...hope you read this!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166510
01/28/12 01:45 PM
01/28/12 01:45 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
I have a few of AndyF's pieces and would certainly add that one if he made it to my combo.
Damon
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: mopardamo] #1166511
01/28/12 03:48 PM
01/28/12 03:48 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Damon! Andy's products look to be top notch in quality,and finish! I'm going to PM him..pick his brain a little bit!
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166512
01/28/12 04:47 PM
01/28/12 04:47 PM
So are mine, I trimmed both a low deck and high deck Hi Po Fel Pro valley pan NO BIG DEAL Easy to do with avaition snips or a die grinder Lay your intake minus the carb on the motor with the heads on it torque down and look through the intake ports and see how your manifold to head port alignment is and go from there on gasket thickness selection One of my motors likes one thin Fel Pro gasket under the valley pan and the other motors likes one both above and below the valley pan for perfect alignment Intake ports are absolutely dry now
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166513
01/28/12 05:00 PM
01/28/12 05:00 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Randy, I can make them. CNC cut plates... Let me know, I can make one and send it with the decals you ordered
-Kenny
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: StrokerAspen] #1166514
01/28/12 05:53 PM
01/28/12 05:53 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Kenny..that would be GREAT! I assume you have a 440 block and heads to test-fit with! The gap should be minimal on the plate-to-head fitment,for a leak-proof seal! Please keep me informed on this,Buddy! How's the weather been up there in Alberta?...COLD,I bet! Randy
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166515
01/28/12 06:06 PM
01/28/12 06:06 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
We just used an Indy plate and welded it to the bottom of my intake
Re: VALLEY PLATE FOR A 440...EDDY RPM HEADS??? [Re: Labratt] #1166516
01/28/12 06:13 PM
01/28/12 06:13 PM
Alberta Canada
Alberta Canada
Right on buddy! It's been mild around here this winter, I just took the summer tires off my daily driver last week, and it was because I got a flat. LOL. It is currently 33 deg F right now. Hardly any snow so far. Which is good for me because I have a problem not lowering everything I drive haha.
Tow rig....
