Hurst shifter #1166003
01/27/12 04:07 PM
01/27/12 04:07 PM
Texas US
hemirag Offline OP
hemirag  Offline OP
Texas US
I need the original part # for the 1970 e body Hurst shifter mechanism.
Thanks in advance for your help.
Re: Hurst shifter [Re: hemirag] #1166004
01/27/12 11:21 PM
01/27/12 11:21 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Mopar part # 2950 750
Just my $0.02..
Re: Hurst shifter [Re: hemirag] #1166005
01/28/12 02:54 PM
01/28/12 02:54 PM
With or without console? Not sure if there different for Cuda and Challengers and with the consoles or not The A and B bodys are
Re: Hurst shifter [Re: Cab_Burge] #1166006
01/28/12 03:49 PM
01/28/12 03:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
E body uses the same shifter for either one .
Re: Hurst shifter [Re: JohnRR] #1166007
01/28/12 05:11 PM
01/28/12 05:11 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The shift lever varies between E & B bodies, with & without consoles...
But the shifter gate mechanism is the same, 70 A833 4-SP transmission actually has (2) mounting positions depending upon E or B body...
Also keep in mind that 1970 was the first year of the slide-in lever fastening system which I don't like.. I replaced the Hurst mechanism in my 70 RR with the aftermarket version and mount the shift lever with the (2) bolts, far more rigid and secure.. Also this has the threaded shift stops as well..
Just my $0.02...
Re: Hurst shifter [Re: hemirag] #1166008
01/28/12 06:59 PM
01/28/12 06:59 PM
Texas US
hemirag Offline OP
hemirag  Offline OP
Texas US
Thanks everyone for the info
