Socket size for 1972 B body ball joint at UCA #1165962
01/27/12 03:41 PM
01/27/12 03:41 PM
California
moparbroz Offline OP
California
Looking for the socket size for the top of the upper control arm ball joint. Anybody know if harbro Freight has these? Thanks in advance.
Hebrews 11:1
Re: Socket size for 1972 B body ball joint at UCA [Re: moparbroz] #1165963
01/27/12 03:49 PM
01/27/12 03:49 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You need a ball joint socket...they are not like a normal socket...so no on china tool store..
Mancini, Amazon, etc would have them...
Re: Socket size for 1972 B body ball joint at UCA [Re: moparbroz] #1165964
01/27/12 03:51 PM
01/27/12 03:51 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
They look like this by the way...
Re: Socket size for 1972 B body ball joint at UCA [Re: OzHemi] #1165965
01/27/12 04:03 PM
01/27/12 04:03 PM
California
California
Sears? Craftsman? Is there a size on the socket?
Hebrews 11:1
Re: Socket size for 1972 B body ball joint at UCA [Re: moparbroz] #1165966
01/27/12 04:12 PM
01/27/12 04:12 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I believe you need the middle size of the 3 mopar sized ball joint sockets.
Re: Socket size for 1972 B body ball joint at UCA [Re: moparbroz] #1165967
01/27/12 04:14 PM
01/27/12 04:14 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
I think I'd try Snap-On, Mac or Matco first.
Re: Socket size for 1972 B body ball joint at UCA [Re: aquamist60] #1165968
01/27/12 04:22 PM
01/27/12 04:22 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
You can get them at Summit Racing as well. I believe this is the one for a B-body.
http://www.summitracing.com/parts/SPS-68890
Re: Socket size for 1972 B body ball joint at UCA [Re: moparbroz] #1165969
01/27/12 04:44 PM
01/27/12 04:44 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
you need a 1-29/32" socket like this Matco SPS32
Re: Socket size for 1972 B body ball joint at UCA [Re: moparbroz] #1165970
01/27/12 04:45 PM
01/27/12 04:45 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
i make them out of billet steel,cnc cut not cast or mild better than snap-on and miller
MOPAR OR NO CAR
Re: Socket size for 1972 B body ball joint at UCA [Re: moparbroz] #1165971
01/27/12 04:48 PM
01/27/12 04:48 PM
hemigod426 Offline
hemigod426  Offline
48.00 shipped
MOPAR OR NO CAR
Re: Socket size for 1972 B body ball joint at UCA [Re: NicksGarage] #1165972
01/27/12 06:24 PM
01/27/12 06:24 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Here is the Mancini one..
http://chucker54.stores.yahoo.net/upbajosobebo.html
Think Amazon is similar in price to Summit.
Re: Socket size for 1972 B body ball joint at UCA [Re: OzHemi] #1165973
01/27/12 06:58 PM
01/27/12 06:58 PM
California
California
Thanks everyone.
Hebrews 11:1
Re: Socket size for 1972 B body ball joint at UCA [Re: moparbroz] #1165974
01/27/12 07:02 PM
01/27/12 07:02 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
You "might" find one at Long Beach on Sunday too ? See them from time to time out there but not super often.
Depends on what hurry you are in I suppose...
Re: Socket size for 1972 B body ball joint at UCA [Re: moparbroz] #1165975
01/27/12 07:17 PM
01/27/12 07:17 PM
WV,USA
W
wvmarv Offline
wvmarv  Offline
W
WV,USA
Don't know about H.F. but here is a link to what sears has. Some are not priced too bad.
http://www.sears.com/shc/s/search_10153_...0joint%20socket
Re: Socket size for 1972 B body ball joint at UCA [Re: OzHemi] #1165976
01/28/12 12:00 AM
01/28/12 12:00 AM
Cut and Shoot, TX
kentj340 Online penguin-006
kentj340  Online Penguin-006
Cut and Shoot, TX
This is what Summit and Mancini are re-selling:
http://www.americanmuscle.biz/
Check out their kits and suspension parts.
Re: Socket size for 1972 B body ball joint at UCA [Re: kentj340] #1165977
01/28/12 12:04 AM
01/28/12 12:04 AM
Cut and Shoot, TX
Cut and Shoot, TX
BTW, I could not remove my upper ball joints with a breaker bar on the socket. An impact wrench is what's needed.
Re: Socket size for 1972 B body ball joint at UCA [Re: moparbroz] #1165978
01/28/12 04:35 PM
01/28/12 04:35 PM
SCVpolara Offline
SCVpolara  Offline
Where in CA are you? I could let you bowwor it just leave a deposit
Re: Socket size for 1972 B body ball joint at UCA [Re: SCVpolara] #1165979
01/28/12 08:57 PM
01/28/12 08:57 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
when you start on it loosen the ball joint nuts and break them loose but do not seperate from the spindle as everything flopping around will make your next chore of breaking the balljoint out of control arm much harder---bob
Re: Socket size for 1972 B body ball joint at UCA [Re: savoy64] #1165980
01/29/12 11:14 AM
01/29/12 11:14 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
O'reilly's have them usually, may be able to rent. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Socket size for 1972 B body ball joint at UCA [Re: moparbroz] #1165981
01/29/12 12:44 PM
01/29/12 12:44 PM
WV,USA
W
wvmarv Offline
wvmarv  Offline
W
WV,USA
I used to have one that had both sizes in one socket, think it was SK but can't remember now. That was back when I was a Mechanic for a living. Must have changed a hundred ball joints with it atleast. Best way is to loosen the ball joint from the spindle, leave bj shaft in spindle with the castle nut on it a few threads to hold it. Then break the ball joint loose from the upper control arm with a breaker bar and a cheater pipe. Once broken loose finish taking it out with an impact gun. Be careful when re installing in the upper control arm to no not cross thread the new ball joint. Screw the new ball joint down as tight as you can get it with the impact gun, then make sure its tight with breaker bar and cheater pipe. Put shaft back in spindle, tighten castle nut, install cotter pin. Piece of cake.
