I just got a stock truck 3 piece set up for my 440/727
the bracket on the intake has a hole to stick a drill bit in to lock it.
the rod from the trans lever to bell crank is solid and hooks to bell crank,the long adjustable rod goes on bell crank at the trans bellcrank then up to upper bellcrank.
IIRC,you then remove the drill bit unlocking the rods,hold it all the way forward against the lever stop and adjust the slotted car rod till the back of the slot is in contact with throttle stud.
before i started I closed up the carb rod length and checked it at wide open throttle makeing sure it did not bind on the intake bracket,(it did so slight adjustment need to start) then made the adjustments..run the carb rod out to carb stud,double check it was all the way back when at WOT and both work independant of each other with no binding and the return spring snaps it back at idle.
results may vary..if its from a low deck its like 2-v and 4-v linkage on SB..may need some tweeking to get it just right.
good luck
if you need a pix of a truck set up mine is off on the bench right now
from what i can tell car and truck have a different intake brackets and are in different spots...higher and lower pivot points.
