Re: Lets talk Solid vs. Hydraulic cams
[Re: MoparforLife]
#116549
09/07/08 08:36 PM
09/07/08 08:36 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
The solid I'm considering is the Comp XS274S. Plugging it into the CamQuest program, it showed about 10 more HP @ 500 RPM less, and nearly 40 lb/ft of torque advantage over the XE285HL. Its description says it also requires less compression and converter than the 285, which leads me to believe it would be more streetable. Lets see..... more power, lower in the band, and better streetablility???? Is there anything here that doesn't sound good?
[Re: solidcam]
#116551
09/07/08 08:48 PM
09/07/08 08:48 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Run the solid and don't buy into any argument that a hydrualic will work better.Listen to the other posters who have run both and you will soon see why people like them.It is a no brainer.
I didn't say that the hydraulic works better. What I said is to watch the lift ratings and and take the solid lash adjustment into consideration as to final lift. I did say that the 508/509 out performed the 528 and all were degreed. The 557 out performed the 509/508 hands down. Also there are some classes that hydraulics are the rule.
[Re: MoparforLife]
#116552
09/07/08 09:16 PM
09/07/08 09:16 PM
StealthWedge67
Puyallup, WA
So, the specs on the XS274S are: 238*&.502 in. / 242*& .510 ex. on a 110*cl. I like the power potential I see, but are there any others I should consider that may offer a little more lift.
I know I shouldn't get hung up in wanting a "big" cam. I don't want to fall into the trap of overcamming. I've come to consider the Mopar grinds outdated compared to other brands that have continually updated their technology.... should I consider one of the Mopar solids?
[Re: goldmember]
#116554
09/07/08 10:55 PM
09/07/08 10:55 PM
Posts: 128 West Michigan
76318dart
West Michigan
I ran a .528 cam in my 318. The car ran mid 13's, I put in a .488/.510 hyd. and it ran high 12's. I won't go back to a solid. Yes the new cam was probably a better fit but I was sick of doing the valve lash.
76 dart 318 runs 12.9o @ 103 mph with 1.78 60ft.
[Re: goldmember]
#116556
09/08/08 12:28 AM
09/08/08 12:28 AM
StealthWedge67
Puyallup, WA
This is a weekend driver that goes around 2500 miles & sees the strip a few times a year. I think I would adjust the lash once a year in the winter. If I had to do it once more a year.... no big. I enjoy garage time.
I took a look at Mopars solid cam selection. I don't think there's much updated technology there.
[Re: StealthWedge67]
#116557
09/08/08 02:03 AM
09/08/08 02:03 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
I get the idea that Don was saying it's apples to oranges with HYD to SOLID... I've struggled with this too... Since it's a theoretical, on EXACTLY when things happen on a cam anyway. Toooooo many variables. People took the .528 vs .509 as literal when it is only an example... .528 MP vs .509 MP is 112 LSA vs 108 LSA...Now that's apples to walnuts ..Not to put any words in Knowsnothings's mouth but what he was getting at is all things being EQUAL, LSA, Installed ICL, ect... FWIW there are some tremendous HYD cams on the market and should be not dismissed so easily by those who have not run one yet. Cost is a factor as I understand on this build You're going to need adjust-ability somewhere...If you go solid, were is that ADJ going to be? quality rockers are not cheap, I have $500 in my Comp mags on my 383...and cheap rockers are not quality, ask those that have run CATS ... Adj push rods are a special order, again not cheap soooo....
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
