My '70 'Cuda twin turbo build.
#1165239
01/26/12 06:28 PM
01/26/12 06:28 PM
Posts: 656 Florida
CJD AUTOMOTIVE
It all started years ago as a simple repaint and mild 340 six pak setup. ![](http://i1060.photobucket.com/albums/t445/340cuda/IM000308.jpg)
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: My '70 'Cuda twin turbo build.
[Re: CJD AUTOMOTIVE]
#1165240
01/26/12 06:34 PM
01/26/12 06:34 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Good solid California car. No rust, but the quarters had been hit hard in a previous life. Spent forever scrapping undercoating...but very pleased with what was underneath ![](http://i1060.photobucket.com/albums/t445/340cuda/IM000317.jpg)
#1165241
01/26/12 06:40 PM
01/26/12 06:40 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Rented a commercial blaster, regulated the pressure way down, and burned through 300 lbs. of media... then turning and tapping to remove all media. In the booth and epoxy. ![](http://i1060.photobucket.com/albums/t445/340cuda/IM000330-1.jpg)
#1165242
01/26/12 06:50 PM
01/26/12 06:50 PM
Posts: 656 Florida
CJD AUTOMOTIVE
#1165243
01/26/12 06:52 PM
01/26/12 06:52 PM
Posts: 656 Florida
CJD AUTOMOTIVE
#1165244
01/26/12 06:55 PM
01/26/12 06:55 PM
Posts: 656 Florida
CJD AUTOMOTIVE
#1165245
01/26/12 07:02 PM
01/26/12 07:02 PM
Posts: 656 Florida
CJD AUTOMOTIVE
My goal was to keep this a unibody car. Stock looking 'Cuda with wheels. ![](http://i1060.photobucket.com/albums/t445/340cuda/IM000353.jpg) [IMG]http://i1060.photobucket.com/albums/t445/340cuda/IM000352.jpg[/IMG[IMG]http://i1060.photobucket.com/albums/t445/340cuda/IM000351.jpg[/IMG ![](http://i1060.photobucket.com/albums/t445/340cuda/IM000346.jpg)
#1165246
01/26/12 07:06 PM
01/26/12 07:06 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Now I can hang the suspension for a mockup. 14" rotors and 6 piston brakes up front. 13" 4 pistons out back ![](http://i1060.photobucket.com/albums/t445/340cuda/IM000346.jpg) ![](http://i1060.photobucket.com/albums/t445/340cuda/IM000373.jpg)
#1165247
01/26/12 07:15 PM
01/26/12 07:15 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Next came the back. I pocketed the frame rails to accept a link bar. Built a full floater 9" Speedway rear. It is a decoupled three link with watts link ![](http://i1060.photobucket.com/albums/t445/340cuda/IM000367-1.jpg) Oops. Can't find the build picks. We'll jump to the finished bottom side. I have 1000 of hours of fab on this to make it look like the factory did it. Went so far as to wipe in every weld!! ![](http://i1060.photobucket.com/albums/t445/340cuda/100_0831-1.jpg)
#1165248
01/26/12 07:25 PM
01/26/12 07:25 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Reached the limit on photobucket....will post more later if you guys want to see it.
#1165249
01/26/12 07:40 PM
01/26/12 07:40 PM
Posts: 656 Florida
CJD AUTOMOTIVE
#1165250
01/26/12 07:41 PM
01/26/12 07:41 PM
Posts: 656 Florida
CJD AUTOMOTIVE
[IMG]http://i1060.photobucket.com/albums/t445/340cuda/100_0769.jpg[/IMG ![](http://i1060.photobucket.com/albums/t445/340cuda/100_0767.jpg)
#1165251
01/26/12 07:44 PM
01/26/12 07:44 PM
Posts: 656 Florida
CJD AUTOMOTIVE
and now to make it look like it was built that way from the factory... ![](http://i1060.photobucket.com/albums/t445/340cuda/100_0844.jpg) ![](http://i1060.photobucket.com/albums/t445/340cuda/100_0847.jpg)
#1165252
01/26/12 07:46 PM
01/26/12 07:46 PM
Posts: 656 Florida
CJD AUTOMOTIVE
#1165253
01/26/12 07:51 PM
01/26/12 07:51 PM
Posts: 656 Florida
CJD AUTOMOTIVE
![](http://i1060.photobucket.com/albums/t445/340cuda/100_0775.jpg) and a little teaser on the body. If you look in the wheel well, that's where the exhaust runs back in. Lots of subtle mods. Will post more later. ![](http://i1060.photobucket.com/albums/t445/340cuda/100_0848.jpg)
#1165256
01/27/12 11:32 AM
01/27/12 11:32 AM
Posts: 21,503 It's a dry heat
gtx6970
It's a dry heat
Duh,,,,yes . Keepem coming ,please I am envious of you guys with this kind of shop capabilities and fabrication skills.
[Re: gtx6970]
#1165258
01/27/12 11:57 AM
01/27/12 11:57 AM
Posts: 656 Florida
CJD AUTOMOTIVE
Okay...heres some more. With upwards of 1500 HP, a cage was in order. Didn't want anything obtrusive, so I sucked in into the roof and A-pillars. I'll widen the A-pillar and headliner trim so you really will have to look hard to see it. ![](http://i1060.photobucket.com/albums/t445/340cuda/100_0836.jpg) ![](http://i1060.photobucket.com/albums/t445/340cuda/100_0835.jpg) I am using a decoupled three thing rear suspension. This requires an upper link used when braking. This changes the IC and loads the rear under braking. The lower torque arm moves the IC the other way, and loads the rear under acceleration ![](http://i1060.photobucket.com/albums/t445/340cuda/100_0834.jpg)
