Page 1 of 12 1 2 3 11 12
My '70 'Cuda twin turbo build. #1165239
01/26/12 06:28 PM
01/26/12 06:28 PM
CJD AUTOMOTIVE Offline OP
It all started years ago as a simple repaint and mild 340 six pak setup.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165240
01/26/12 06:34 PM
01/26/12 06:34 PM
Good solid California car. No rust, but the quarters had been hit hard in a previous life. Spent forever scrapping undercoating...but very pleased with what was underneath
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165241
01/26/12 06:40 PM
01/26/12 06:40 PM
Rented a commercial blaster, regulated the pressure way down, and burned through 300 lbs. of media... then turning and tapping to remove all media. In the booth and epoxy.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165242
01/26/12 06:50 PM
01/26/12 06:50 PM
This is where things started to change directions. I looked into everyones K-frames, and all suffered from lack of camber in compression. This was years before XV was in existence. I build a jig of of a C5 Vette, removed the aprons and built a K-frame.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165243
01/26/12 06:52 PM
01/26/12 06:52 PM
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165244
01/26/12 06:55 PM
01/26/12 06:55 PM
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165245
01/26/12 07:02 PM
01/26/12 07:02 PM
My goal was to keep this a unibody car. Stock looking 'Cuda with wheels.[IMG]http://i1060.photobucket.com/albums/t445/340cuda/IM000352.jpg[/IMG[IMG]http://i1060.photobucket.com/albums/t445/340cuda/IM000351.jpg[/IMG
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165246
01/26/12 07:06 PM
01/26/12 07:06 PM
Now I can hang the suspension for a mockup. 14" rotors and 6 piston brakes up front. 13" 4 pistons out back
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165247
01/26/12 07:15 PM
01/26/12 07:15 PM
Next came the back. I pocketed the frame rails to accept a link bar. Built a full floater 9" Speedway rear. It is a decoupled three link with watts link
Oops. Can't find the build picks. We'll jump to the finished bottom side. I have 1000 of hours of fab on this to make it look like the factory did it. Went so far as to wipe in every weld!!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165248
01/26/12 07:25 PM
01/26/12 07:25 PM
Reached the limit on photobucket....will post more later if you guys want to see it.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165249
01/26/12 07:40 PM
01/26/12 07:40 PM
You can see the headers I mocked up for the small block in the last photos. Now junk, because I decided on a twin turbo R3 engine...Okay time to make that fit.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165250
01/26/12 07:41 PM
01/26/12 07:41 PM
[IMG]http://i1060.photobucket.com/albums/t445/340cuda/100_0769.jpg[/IMG
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165251
01/26/12 07:44 PM
01/26/12 07:44 PM
and now to make it look like it was built that way from the factory...
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165252
01/26/12 07:46 PM
01/26/12 07:46 PM
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165253
01/26/12 07:51 PM
01/26/12 07:51 PM
and a little teaser on the body. If you look in the wheel well, that's where the exhaust runs back in. Lots of subtle mods. Will post more later.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165254
01/26/12 09:04 PM
01/26/12 09:04 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Great Project!! Are you gonna use the 340 or something else.. Keep us updated.https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6313383&an=0&page=0#Post6313383
Re: My '70 'Cuda twin turbo build. [Re: johnscudashop] #1165255
01/27/12 10:26 AM
01/27/12 10:26 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
WOW this is a KILLER build!
Keep the pics coming!
Re: My '70 'Cuda twin turbo build. [Re: CJD AUTOMOTIVE] #1165256
01/27/12 11:32 AM
01/27/12 11:32 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Duh,,,,yes . Keepem coming ,please
I am envious of you guys with this kind of shop capabilities and fabrication skills.
Re: My '70 'Cuda twin turbo build. [Re: johnscudashop] #1165257
01/27/12 11:40 AM
01/27/12 11:40 AM
Thanks. Not using a 340, using a tall deck R3 360 block.
Checked out your project as well. Looks good!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: My '70 'Cuda twin turbo build. [Re: gtx6970] #1165258
01/27/12 11:57 AM
01/27/12 11:57 AM
Okay...heres some more.
With upwards of 1500 HP, a cage was in order. Didn't want anything obtrusive, so I sucked in into the roof and A-pillars. I'll widen the A-pillar and headliner trim so you really will have to look hard to see it.
I am using a decoupled three thing rear suspension. This requires an upper link used when braking. This changes the IC and loads the rear under braking. The lower torque arm moves the IC the other way, and loads the rear under acceleration
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
