Re: best control arms for lowered E-body
[Re: phil4161972]
#1164630
01/26/12 04:17 AM
01/26/12 04:17 AM
Posts: 27,548 So Cal
autoxcuda
So Cal
hey guys, I have a 72 cuda that I have lowered, with the stock lower control arms I have negative caster and to much negative camber such that it wears the front tires out pretty quickly. I am looking at purchasing a set of tubular control arms to correct this situation and was wondering if you guys could recomend the best ones to fix my problems. Thanks
Have you taken it to and alignment shop after you lowered it?
Install Moog offset upper control arm bushing pn 7103. Do not install per directions, install per directions in picture below.
Many others and myself have run lowered mopars with stock UCA's.
The bigger issue is the distance between the lower control arm (LCA) and the frame where the bump stop is.
[Re: phil4161972]
#1164637
01/27/12 01:28 AM
01/27/12 01:28 AM
Posts: 7,664 IN
ahy
IN
Yes sir all the cam eccentrics are in roughly the same position on both sides. I dont have the printout it has been a few years since it was done so I do not have the exact numbers It has those poly strut rod bushings in it which I was considering cutting down to pull the LCA up towards the front of the car some, or would it be better just to pay up for the adjustable strut rods?
At the end of the day what I would like to be able to do is put it togeteher one time get it aligned, and not have to mess with it anymore.
I went a "couple rounds" on the alignment with mine. With the poly LCA bushings I have, strut rod length needs to be perfect to keep everything in place. Mine wasn't on one side which had +/- 1/8" slop and threw the alignment off. I considered cutting the strut rod bushings and decided to go with the adjustable rods (Firm Feel) instead. Same reason you are thinking... I didn't want to tear it apart several times while I adjusted the bushings on my belt sander by trial and error.
If you do go with adjustable rods, use the adjustment sparingly... too much pull forward will bind up and wear out the LCA bushings. In my case, they worked beautifly. I was able to tighten up the left side that was sloppy and the alignment cam in as desired.
[Re: phil4161972]
#1164640
01/27/12 12:50 PM
01/27/12 12:50 PM
autoxcuda
So Cal
I have it took all apart now so no readings will be had, probably should have had someone throw it on the rack to get some intial readings to go from. Oh well. But with the alignment where it was it would wear the inside of the tire down to almost blistering in 10-15 thousand miles, considering this isnt a daily driver thats not terrible but it would be nice to get it right. You got that much caster with just offset bushings and a shaved down strud rod bushing?
Yes. Correct.
I have a 16 to 1 flaming river box I would assume that much caster would make it a little tough in parking lots?
Probably. I have power steering. There is a theard on how much caster with manual steering here.
