Replacing brake lines to disc/disc combo on '71 Cuda? #1163959
01/24/12 03:09 AM
01/24/12 03:09 AM
808CUDA Offline OP
808CUDA  Offline OP
Ok, I have a '71 Barracuda with factory power disc brakes and rear drums.
I'm going to run manual brakes (aluminum master) with factory front disc brakes and rear disc brakes.
Which brake line set should I order from inline tube if I want to do away with the 2-piece prop valve?
Do I get brake lines & prop valve for a '72 Cuda with manual disc/drum set up?
Thanks in advance!
Re: Replacing brake lines to disc/disc combo on '71 Cuda? [Re: 808CUDA] #1163960
01/24/12 05:28 PM
01/24/12 05:28 PM
808CUDA Offline OP
808CUDA  Offline OP
Ended up ordering a brake line set for a manual drum brake car along with distribution block and adjustable prop valve.
Now what size aluminum master cylinder bore to get?
Re: Replacing brake lines to disc/disc combo on '71 Cuda? [Re: 808CUDA] #1163961
01/24/12 06:25 PM
01/24/12 06:25 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I usually run the standard single piece dist block, but what you got will work well. 7/8 or 15/16, 1 1/16 at most.. I have a 1.125 on my Dart with no probs, but the B bodies I have done need more pressure. Smaller bore, higher pressure. I have a 1 1/16 that's has only a few miles on it if you need one.
Re: Replacing brake lines to disc/disc combo on '71 Cuda? [Re: 808CUDA] #1163962
01/24/12 08:42 PM
01/24/12 08:42 PM
MT
cudabruce Offline
cudabruce  Offline
MT
Just finished my brakes on Cuda. Wilwood disc on all four and used a 1-1/16 bore master cylinder. It works great.
Re: Replacing brake lines to disc/disc combo on '71 Cuda? [Re: cudabruce] #1163963
01/25/12 03:01 AM
01/25/12 03:01 AM
808CUDA Offline OP
808CUDA  Offline OP
Thanks for the input! Much appreciated!
