I am looking for the correct length brake shoe return springs for
a '69 B-body with 11" drums, front and rear.
I have tried springs from Raybestos H-111, and others show the same
number. The problem is with the springs, once installed there is a .020"
gap between each coil. My originals are one coil longer and when
install there is no gap as should be. I'd like to replace the
originals due to there age.
