How to tell if King Pins need relaced ?
#1162492
01/22/12 04:43 AM
01/22/12 04:43 AM
Posts: 1,832 Fort Morgan
1OFNONE
Has been a member for quite a few years, so relax.
Fort Morgan
Do they drive crappy or what ?
So the bartender says to the horse " Gee, Why the long face?"
Re: How to tell if King Pins need relaced ?
[Re: 1OFNONE]
#1162493
01/22/12 05:06 AM
01/22/12 05:06 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Excess movement or binding are the normal reasons to replace the pins & bushings... Typically driving crappy is due to other problems... What are you working on that has king pins?
[Re: 1OFNONE]
#1162494
01/22/12 09:31 AM
01/22/12 09:31 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
What do you have that still has king pins?
[Re: MoparforLife]
#1162495
01/22/12 11:19 AM
01/22/12 11:19 AM
Posts: 2,673 Northern MN
1E2C
Northern MN
Dunno what the OP has, but I'm having a fit doing them on a 40 Ford right now. Having some trouble finding the correct reamer to size the bushings once installed. Mike Oh - I decided they needed replaced because the wheel had movement up and down when when wiggled, could see the motion was in the kingpins.
[Re: 1E2C]
#1162496
01/22/12 12:22 PM
01/22/12 12:22 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Shims control the up and down, not the king pins. But since you have to strip it down to shim it you may as well inspect the king pins and bushings.
[Re: Supercuda]
#1162497
01/22/12 12:43 PM
01/22/12 12:43 PM
1OFNONE
Fort Morgan
A buddy of mine is working on an old '46 pickup. He started asking questions that I didnt know the answer to.
[Re: moretoys]
#1162500
01/22/12 02:14 PM
01/22/12 02:14 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
As far as driving crappy adding a little caster & setting the toe can help allot... Worn linkages & steering gear are also common issues..
[Re: 1E2C]
#1162503
01/22/12 02:50 PM
01/22/12 02:50 PM
Supercuda
About to go away
About to go away
up yours
I would have a shop line hone them, makes for a better and longer lasting job than a reamer.
[Re: 1OFNONE]
#1162504
01/22/12 02:58 PM
01/22/12 02:58 PM
He might want to check his drag link. If it's worn, it can have a terrible shimmy/wobble at highway speeds.
[Re: Supercuda]
#1162505
01/22/12 03:55 PM
01/22/12 03:55 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Kevin
[Re: Twostick]
#1162506
01/22/12 04:17 PM
01/22/12 04:17 PM
1E2C
Northern MN
Kevin
Probably true, but the machine shops near here are somewhat, shall we say, less than top-notch. I haven't really checked closely and kinda hope one can do it, but many of them tend to get cross-eyed if it's anything off the beaten path.
[Re: Cab_Burge]
#1162509
01/22/12 09:22 PM
01/22/12 09:22 PM
1OFNONE
Fort Morgan
Hey guys once again Moparts comes thru !!!
Thanks everyone.
