A-body 8.75 with /6
#1161884
01/21/12 10:10 AM
01/21/12 10:10 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
You fellow junk yard dogs need to be checking the rears on all the A-bodies you find. Even /6 cars. Just picked up this 71 Dart /6 3-sp w/ disc and 8.75 A friend has a 72 Duster that he bought from the original owner. /6 auto w disc and 8.75
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: A-body 8.75 with /6
[Re: moparmarks]
#1161887
01/21/12 10:36 AM
01/21/12 10:36 AM
RapidRobert
Good for you, sometimes Lady Luck comes our way, makes up for the occaisional mishap/misfortune. I imagine Ma used what she had on hand if an item/inventory came up short as stopping the line was the last thing a foreman wanted to have happen on his shift
[Re: moparmarks]
#1161890
01/21/12 02:55 PM
01/21/12 02:55 PM
Posts: 11,081 Berlin, N.J.
abodyjoe
Berlin, N.J.
not uncommon at all.. have seen quite a few of them. even saw a friends 4 door, had 8 3/4 front disc brake and front sway bar.
just parted this one out a few years ago. six cyl, front disc brake, and 8 3/4. also had a rim blow wheel..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: moparmarks]
#1161894
01/21/12 04:13 PM
01/21/12 04:13 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
I think the manual trans even in /6 tended to get the bigger rear end after 1970. Maybe something to do with the weight of the cars getting more and more as time went on. And/or warranty claims on 7.25 rears.
It seems a lot of these /6 and 318 1970 to 1972 Abodies with 8 3/4 tend to be sort of loaded (weight). A lot seem to have that option package that included the rim blow steering wheel. 8 3/4 and rim blow wheels seem to pair up often. And most of those also have A/C.
I don't think they were dumping this rear end in 70 and 71. I can sort of see late 1972. But Mopar didn't carry a complete 1 year inventory on rear ends.
[Re: Kern Dog]
#1161896
01/21/12 04:31 PM
01/21/12 04:31 PM
autoxcuda
So Cal
Either the 7.25 was upgraded over the years or something is wierd. I have seen several LOADED 73-76 slant six 4 door Valiants and Darts with the 7.25 axle. They theoretically should have had the 8.25 if durability was a concern. I stick with the towing package theory. HD axle, Trans cooler in HD radiator and 7 blade fan with fan clutch.
Oh I agree. The later cars seem skimpy with the 8 1/4" rear. Although I do know of a 74 Dart Sport convertiple with /6 manual trans and 8 1/4". I'm thinking the manual trans did it.
But I don't think all those car we're finding the rear ends have trailer towing. MoparMarks, does the fender tag on those cars show trailer towing? Is trailer towing even on the fender tag?
Now IIRC, disk brakes automatically got you HD suspension.
[Re: Kern Dog]
#1161898
01/21/12 04:52 PM
01/21/12 04:52 PM
autoxcuda
So Cal
Ah... disc brakes! THAT makes sense too......
Of the 5 cars mentioned on this thread with 8 3/4 rears, 5 had disc brakes.
This one didn't mention what brakes it had?:
My 70 duster (also for sale) is an 8.75 318 auto car
This one is not certain what rear end it had originally. -but note it did have A/C, 318, vinyl top and the bigger looking front drums-
Heres another 71 Dart /6. About the only thing missing is the rear end. Hmmmmmmm.
[Re: copperSwinger]
#1161900
01/22/12 12:21 PM
01/22/12 12:21 PM
Posts: 20,203 Park Forest, IL
slantzilla
Park Forest, IL
I would guess you got it when you spec'ed disc or 10" drums. I've never seen any 10" drums for small bolt pattern 7-1/4" rears.
In '73 they started using the 10" drums on BBP 7-1/4" with the BBP disc.
[Re: DoctorDiff]
#1161902
01/22/12 03:05 PM
01/22/12 03:05 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
The A bodies around here usually never make it past the front gate at PullaPart with the 8 3/4's or disc brakes. There is a Mopar guy that snags them all.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Rug_Trucker]
#1161903
01/22/12 10:34 PM
01/22/12 10:34 PM
Posts: 6,653 Near Reading PA USA
pinkduster
Near Reading PA USA
My 71 Duster Twister has 10" drums and the 7.25 rear. The local old time junkyard had (for years) a 70 Duster /6 3speed car with the 8.75 rear, but somebody took the axles and brakes a long time ago and everything was rusty as hell so nobody ever bought it. I've been into A-bodies for 25+ years and sometimes it would surprise you to find 8.75 rears under cars that you wouldn't think would have them. I learned to look under EVERY car, cause you just never know.
