400 block 440 Mains #1161789
01/21/12 12:36 AM
01/21/12 12:36 AM
Long Island, New York
cochez Offline OP
super gas
cochez  Offline OP
super gas
Have not posted on the board for years... Engine build came to a halt for personal reasons... I have a 400 block BCR Alum caps and 440 4.25 stroke crank w/ Chevy rod journals.. Is anyone still line boring 400 Blocks to 440 Mains??? Most Machinest I've talked to won't do it... Anyone had issues since 2006 when I last posted?
Re: 400 block 440 Mains [Re: cochez] #1161790
01/21/12 01:00 AM
01/21/12 01:00 AM
IN
ahy Offline
ahy  Offline
IN
The longer stroke cranks with 400 mains seem to do fine if it is a good steel crank.
I know Rich Eherenberg did the "over bore" mains on a low deck MA project car and don't know of any problems... perhaps he'll post.
If you have already bored the mains oversize, I'd put it together and run it. Otherwise, it might be easier, cheaper, better(?) to simply get the crank turned down to low deck size mains.
Re: 400 block 440 Mains [Re: ahy] #1161791
01/21/12 01:04 AM
01/21/12 01:04 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
440jim did it to his 400 , no problems reported , that I have seen . A plus is better choice of main bearings .
Re: 400 block 440 Mains [Re: ahy] #1161792
01/21/12 01:06 AM
01/21/12 01:06 AM
cochez Offline OP
super gas
cochez  Offline OP
super gas
I have a good chunk invested in this Crank (Callies) and would rather not cut it (a more expensive process...to have it re-hardened and rebalanced etc.)... wondering if there are drawbacks since a few places won't do it (or maybe they can't)???
Re: 400 block 440 Mains [Re: cochez] #1161793
01/21/12 01:11 AM
01/21/12 01:11 AM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
well if they do not want to do it on the main caps being on the thin side put a good stud girdle on it with main caps. then they have to be bored and have more metal. maybe they will like that.
Re: 400 block 440 Mains [Re: dmking] #1161794
01/21/12 01:28 AM
01/21/12 01:28 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
My old motor is a 400 block with 440 mains and even tho it was only 650-ish HP.. We did not see any problems with it..
Re: 400 block 440 Mains [Re: dmking] #1161795
01/21/12 01:31 AM
01/21/12 01:31 AM
cochez Offline OP
super gas
cochez  Offline OP
super gas
I actually copied his build way back when...and hoped he'd chime in... if he remembers me... I have a place to do it (Weston Machine) and also the main girdle from Chenoweth... I'm trying to get this project up and running again... Really I would like to see some pics if anyone has any? Or links I could check out......
Re: 400 block 440 Mains [Re: Jeepmon] #1161796
01/21/12 01:32 AM
01/21/12 01:32 AM
cochez Offline OP
super gas
cochez  Offline OP
super gas
did you take any pics???
Re: 400 block 440 Mains [Re: cochez] #1161797
01/21/12 03:15 AM
01/21/12 03:15 AM
AndyF Offline
AndyF  Offline
It is a real pain to machine the main line that much. Plus the bearing tang reliefs then have to be cut into the block which isn't an easy process. The only shops that can do this type of work economically are the ones with high dollar CNC equipment. Depending on where you live, you might have to travel a fair distance to find a shop who can even do that type of work.
Re: 400 block 440 Mains [Re: AndyF] #1161798
01/21/12 03:53 AM
01/21/12 03:53 AM
Delray beach, Florida
P
Performance Only Offline
P
it's not really a big deal IMO. back before I bought the CNC, we just did them the old fashioned way. the CNC makes it a little easier now.
when 440jim bought his Callies crank from me we discussed the option of opening the blocks mains so he wouldn't have to cut the journals on the crank. IMO and obviously Jim's as well, it was better to cut the block. i think the longevity of his engine as well as the performance speaks for itself.
machine shop owner and engine builder
Re: 400 block 440 Mains [Re: Performance Only] #1161799
01/21/12 10:44 AM
01/21/12 10:44 AM
cochez Offline OP
super gas
cochez  Offline OP
super gas
If This is Dan? I got my Crank, Rods & Pistons from you also. (Have not put it together yet) I haven't been up on the latest and greatest for the last few years.... I'm trying to reclaim all the data I've lost over the years and finally get this up and rolling again. This is Rich if you remember me????
Re: 400 block 440 Mains [Re: cochez] #1161800
01/21/12 11:42 AM
01/21/12 11:42 AM
NC
440Jim Offline
440Jim  Offline
NC
My 511 CID low deck (4.375 x 4.250 stroke) has aluminum main caps and enlarged to 440 size. I run a Callies crank. This block has almost 800 passes now. I was so happy back in the winter of 2010-2011 I did the same main change to my spare 400 block.
Re: 400 block 440 Mains [Re: cochez] #1161801
01/21/12 12:18 PM
01/21/12 12:18 PM
NC
440Jim Offline
440Jim  Offline
NC
That is who I used. Highly recommend that shop. They will get it done right, and turn it around quickly. No 3 month wait like some shops...
Re: 400 block 440 Mains [Re: 440Jim] #1161802
01/21/12 12:25 PM
01/21/12 12:25 PM
cochez Offline OP
super gas
cochez  Offline OP
super gas
Yes! I copied your short block plans... good to hear no issues my stuff has been on the shelf since 2006... Did you have to notch the block at all and what kind of oil system do you run...
I was suposed to drop the block of today but Snow is in the way...
Re: 400 block 440 Mains [Re: cochez] #1161803
01/21/12 12:40 PM
01/21/12 12:40 PM
NC
440Jim Offline
440Jim  Offline
NC
As I recall, the rod bolts (2.200 H-beam) cleared the cylinder bores, but I ground clearance there anyway while I was preparing the block. I did have to just touch the oil pickup boss on the block, picture attached. I run a 1/2 NPT Moroso internal pickup. I had the Callies 4.250" crank counterweights turned down to 7.14" dia before balancing, 2185 gram bobweight.
Re: 400 block 440 Mains [Re: 440Jim] #1161804
01/21/12 10:15 PM
01/21/12 10:15 PM
cochez Offline OP
super gas
cochez  Offline OP
super gas
did you turn the counterweights down to reduce mass? Or was there clearance issues?
Re: 400 block 440 Mains [Re: cochez] #1161805
01/21/12 10:29 PM
01/21/12 10:29 PM
NC
440Jim Offline
440Jim  Offline
NC
The counterweights need to be turned down to 7.25" dia to clear a low deck block. Or grind clearance in the block, or put 3/8" bevels on the counterweights. But since the bobweight is so "low" (for a steel rod motor), reducing the counterweights helps balance the crank without putting big holes in it. I tell everyone, each crank brand, stroke, and bobweight is different. So, go carefully when cutting smaller than 7.25" dia. The shop actually checked it on the balancer at 7.20", before cutting the dia down even farther. Then a fine balance with a shallow hole.
