Re: hemi cross ram carbs
[Re: copchaser]
#1161617
01/21/12 10:07 AM
01/21/12 10:07 AM
Posts: 2,252 Sebring, Florida
Mopar Grandpa
Sebring, Florida
I purchased my intake and carbs, both 4236's, from A&A Transmission. Rick didn't say one was the left and one was the right. I think they are both the same regarding the jetting as they don't operate in progression. If in doubt call Rick at A&A. BTW, my engine produced 75 LESS h.p. with the cross ram vs. a single high rise and 850 Holley. Are you going for the look or for h.p.and torque?
[Re: copchaser]
#1161620
01/21/12 03:07 PM
01/21/12 03:07 PM
Posts: 3,505 DFW
mr_340
DFW
Carb. Primary & Primary Secondary Primary Secondary Primary Carburetor Model CFM Renew Trick Secondary Main Main Jet Metering Metering Primary Discharge Part No. No. Kit Kit Needle Jet or Plate Block Block Power Valve Nozzle
0-4235 4160 770 37-485 37-933 6-504 (29) N/S N/S N/R 125-65 .035 0-4236 4160 770 37-485 37-933 6-504 122-80 N/S N/S N/R 125-65 .035
(29) 122-75 Diaphragm side; 122-80 Throttle Lever side
I'm not sure if this will paste in any sort of order than makes sense. I'll try to copy the PDF file here as well, but I don't think I can attach those on this site. Basically the 4235 has different primary jets, 75 on DS, 80 on the TS.
Floyd Lippencott IV
[Re: copchaser]
#1161622
01/23/12 12:43 PM
01/23/12 12:43 PM
Posts: 642 New Jersey
Craig
New Jersey
I ran the 4235/4236 carbs on an original crossram, they were the staggered jetting, but Barton recommended 80s and .073s all around and that did run better. This is on a roller cammed 12.5:1 Hemi with about 200psi cranking compression.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
