hemi rocker choice #1161445
01/20/12 04:26 PM
01/20/12 04:26 PM
saint paul mn.
johnzgarage Offline OP
saint paul mn.
Im building a 65 belvedere sedan a990 clone. The engine is a 472 cid , 12.5 comp. , solid roller cam and mp aluminum heads . The car will be used mainly for street fun and show, maybe a run or two down the strip. I havent picked out a rocker system yet. Do i need really need to go all $$$$$ on a set rockers shafts and stands, or will a cheaper setup like the one on ebay(sorry) work fine? Wouldnt the stock setup and roller tips on the intake work fine??? I really cant see paying for stage v stuff, when the engine will be rarely push hard. What type of problems might I have with stock parts ???
Re: hemi rocker choice [Re: johnzgarage] #1161446
01/20/12 04:58 PM
01/20/12 04:58 PM
California
mickm Offline
mickm  Offline
California
it depends on how radical the cam is. personally, i think the stock setup is good for a lot more than most think. stage V is incredible stuff, (a while back i was working on herb's car with him, i walked up to the engine compartment and he had the valve cover off, and it literally took my breath away! they are works of art, especially when all in place on the head!), but unless it is high horsepower and radical cam specs, i don't think it is necessary.
stock wide pad rockers with the geometry set correctly will do the trick.
Re: hemi rocker choice [Re: mickm] #1161447
01/20/12 05:23 PM
01/20/12 05:23 PM
saint paul mn.
saint paul mn.
I havent picked the exact cam yet, but I will try to match it to the max head flow cfm @ 3800-4800 rpm range and what my valve springs can take. Just needs to sound like the old super stockers....I forgot to add that it has a cross ram and 770 carbs.
Re: hemi rocker choice *DELETED* [Re: johnzgarage] #1161448
01/20/12 06:34 PM
01/20/12 06:34 PM
Sparta, TN
mark42202 Offline
mark42202  Offline
Sparta, TN
Post deleted by moparts
Re: hemi rocker choice [Re: mark42202] #1161449
01/20/12 07:24 PM
01/20/12 07:24 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
You can safely life with stock rockers other than all out 9,000rpm .850 lift cams.
I have used narrow pads on motors that regualrly saw 8,000 RPm without trouble.
are there better ones ? yes but do you need to buy them ?
I WOULD FIND A BETTER PLACE FOR MY MONEY
home of the
Sox and Martin Hemi Duster
Re: hemi rocker choice [Re: HEMIFRED] #1161450
01/20/12 10:10 PM
01/20/12 10:10 PM
OHIO
THE GLASS MAN Offline
OHIO
Re: hemi rocker choice [Re: THE GLASS MAN] #1161451
01/21/12 12:58 AM
01/21/12 12:58 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
these are from Arlen's Cuda 70's pro stocker and saw 9,000 rpm shift points every pass back then.
The geometry was not perfect but I don't remember many breaking
home of the
Re: hemi rocker choice [Re: johnzgarage] #1161452
01/21/12 01:08 AM
01/21/12 01:08 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I haven't heard a single good word about the cheap chinese junk sets being sold cheap on ebay, that is definitely a you get what you pay for.
you buy cheap crap , you get cheap crap .
Re: hemi rocker choice [Re: JohnRR] #1161453
01/21/12 01:29 AM
01/21/12 01:29 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
My understanding is the Canadian guy on Ebay's stuff is junk, I've never seen the stuff but that's what I've heard.
I've only been running Hemi's since 1980, but I've never had a failure of any type with the stock rockers. Yeah the other stuff looks nice but you can't beat the old original Mopar parts for reliability and price.
Sheldon
Re: hemi rocker choice [Re: johnzgarage] #1161454
01/21/12 01:58 AM
01/21/12 01:58 AM
tn
robnbird Offline
robnbird  Offline
tn
Im building a 542ci indy heads with indy rockers. stock will work fine for street and strip. In other word no rollers. And you don't need them. However if you want them and mine are a new complete set indy rollers, stands, and rocker shafts and springs for 1800. there are some stock type on racing junk under engine parts for around 1000 I think.
Re: hemi rocker choice [Re: JohnRR] #1161455
01/21/12 02:15 AM
01/21/12 02:15 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
As far as I know we haven't heard any complaints here which shocks me. Maybe no one here used them or had problems and is not about to post it?
I do know of one set that had terrible ratio variations
I think I have a decent stock set around for 1K
home of the
Re: hemi rocker choice [Re: johnzgarage] #1161456
01/21/12 02:34 AM
01/21/12 02:34 AM
tn
robnbird Offline
robnbird  Offline
tn
for street and an occasional blast down the track stock are fine. However if you have to spend 1500 for stock, go the extra for rollers.
Re: hemi rocker choice [Re: robnbird] #1161457
01/21/12 01:49 PM
01/21/12 01:49 PM
saint paul mn.
saint paul mn.
Thanks for all the anwsers. I think I will shop around for a nice oem set, but if I see a great deal on a trick roller set, I might jump on it !!!!!!
Re: hemi rocker choice [Re: johnzgarage] #1161458
01/21/12 02:16 PM
01/21/12 02:16 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Stage Vs are the best I've seen,but for under $2000 you can buy a complete set of Indy roller rockers with shafts,clamps,aluminium stands,side springs and shims.The Indy set with the adjustable steel stands is about $300 more.A set of intake and exhaust rockers are a little over $1000.We have had great results with the Indys on all our Hemi builds.
Re: hemi rocker choice [Re: B G Racing] #1161459
01/21/12 04:48 PM
01/21/12 04:48 PM
Netherlands
72Challenger Offline
Netherlands
I've been running stock 'narrow' ones for years like Fred said. No problems but I'm only running 7000 rpms with a solid flat tappet cam 283@050 .667 lift. I think it mostly depends on spring pressures vs rpm you gonnan run...
Re: hemi rocker choice [Re: HEMIFRED] #1161460
01/24/12 10:12 AM
01/24/12 10:12 AM
an8sec70cuda Offline
Back when I was building my hemi in 2006, I asked about those cheap ebay canadian rockers. I forget who it was, but someone here told me they'd had a set and the geometry was so bad they sent them back.
I went w/ DLI rollers. My dad's street hemi will have a set of factory widepads.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: hemi rocker choice [Re: an8sec70cuda] #1161461
01/25/12 09:34 AM
01/25/12 09:34 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Re: hemi rocker choice [Re: Defbob] #1161462
01/25/12 09:36 AM
01/25/12 09:36 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
someone else's motor here
Re: hemi rocker choice [Re: Defbob] #1161463
01/25/12 09:44 AM
01/25/12 09:44 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
How about the Barton / T&D set up?
Plynouth VIP '67 TT IC EFI
Re: hemi rocker choice [Re: jyrki] #1161464
01/25/12 09:57 AM
01/25/12 09:57 AM
Very nice, but expensive and unnecessary unless you're running 8k+ rpm.
CHIP
