Page 2 of 5 1 2 3 4 5
Re: Subframe connector options and opinions #1161188
01/21/12 11:53 AM
01/21/12 11:53 AM
Here
jcc Offline
jcc  Offline
Here
The first question should be IMO, could someone describe and BACK UP at least, with sound reasoning, what actual forces sub frame connectors resist? I am not questioning many many positive reports of their improvements in ride etc. So are they resisting compression as the rear leafs push forward upon acceleration, are they resisting twist individually, if just under tension we can just use a steel cable, are they preventing a bending moment as front of leaf pushes up upon acceleration with a bending moment provided by the front mass of the car, ie engine, etc, are they just straightening out the force path thru 4 right? angle turns from the front hanger to the doorsills back to the TB crossmember, etc?.
If we knew what they are resisting, it would be a lot easier to design a solution. I suspect they are doing all the above, but some more then others, but which one? Say if twist was the main force, a large dia tube would be first choice, if bending moment, a tall I beam, yaw? bending, an I beam on its side, etc. My understanding is it needs to be the smallest and lightest shape/size that gets the job done. Anyone can oversize a solution, only a smart designer knows just how much is needed, if you way oversize, you look.....?
Years back member AAR? (patent attorney) had a lengthly thread on Subframe connectors, and main conclusion was the larger the crossection of the subframe, the stiffer, wall thickness provides a lot less stiffness then crossection increase gives. The installation advantages are numerous with the contour cut-out connectors, and installation ease IMO is thier only advantage. Performance wise, compared to a full tube they leave a lot on the table.
Aren't the factory rockers in effect thick gauge sorta-square tubes connecting the front and rear subframes? If so, what do aftermarket subrame connectors do that they don't? Just add strength to the connection because you now have four subrame connectors instead of two? Perform some other function?
And although it might present clearance issues for driveshaft and/or exhaust, wouldn't an X-shaped subframe connector be much more rigid than two straight tubes?
IMO you are correct, add on sub frame connectors are just straighter factory rockers, on steroids.
An "X" design is usually just a replacement for a flat shear plate, for many reasons, some obvious, but an X would mainly be beneficial in this application would be if a force was being say applied by only one wheel during acceleration, and therefore trying to "shear" the car, however if an "x" was on four planes, bottom, top, sides, you would then have a very large "tube", and that would resist greatly any twist/torsion forces, which is of choice what most race cars accomplish with a full cage, but an x on one side doesn't seem to me get very much buck for bang.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: Subframe connector options and opinions [Re: jcc] #1161189
01/21/12 12:28 PM
01/21/12 12:28 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
i used the uscartool connectors on 2 cars. i think they are way over priced for a frame connector, compared to how cheap you can buy a length of tube, but they are really nice. weld to the floor pan from the front cross member all the way back to the rear rails.
Re: Subframe connector options and opinions [Re: JAMESDART] #1161190
01/21/12 12:51 PM
01/21/12 12:51 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
No way the Hotchkis connectors are better than what I did on my car.
Ground clearance is defintely better on mine.
Also rigidity is way superior, even when Im just using 2" x 2" square tube.
Mine look like if it was a factory deal really....
I also cut the rear frame rails some so that the connector tucks in some....it isnt welded under the frame rail.
Re: Subframe connector options and opinions [Re: domingo] #1161191
01/21/12 12:53 PM
01/21/12 12:53 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Re: Subframe connector options and opinions [Re: domingo] #1161192
01/21/12 12:54 PM
01/21/12 12:54 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
more...
Re: Subframe connector options and opinions [Re: domingo] #1161193
01/21/12 12:56 PM
01/21/12 12:56 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
see how a section of the rear frame rail is cut...also, the E brake brackets need to be modified a bit, but they stay on the factory location and work just like factory. Everything will bolt of afterwards. And the fron sections that tie on the front frame rails do not get in the way of anything.
Re: Subframe connector options and opinions [Re: domingo] #1161194
01/21/12 12:58 PM
01/21/12 12:58 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
mocking up. The e bodies do not have the rear frame rails parallel to the rockers, so you need to incorporate a kink on the tube by cuttong a slice and welding....same for the kink for the front frame rail ties.
Re: Subframe connector options and opinions [Re: domingo] #1161195
01/21/12 01:00 PM
01/21/12 01:00 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
mocking up
Re: Subframe connector options and opinions [Re: domingo] #1161196
01/21/12 01:01 PM
01/21/12 01:01 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
VIEW FROM THE OTHER END
Re: Subframe connector options and opinions [Re: domingo] #1161197
01/21/12 01:03 PM
01/21/12 01:03 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
protrusion in the passenger compartment is minimal. Jute padding on the sides and carpet on top will take care of it and the interior will look factory.
Re: Subframe connector options and opinions [Re: domingo] #1161198
01/21/12 01:10 PM
01/21/12 01:10 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
e brake bracket that needs to be modified....thats it!
Then if you want to you add the torque boxes I sell below and YOU ARE ALL SET. Super strong and you dont ruin your car as this is a mod I dont think you will regret or that will prevent you from enjoying your car as if it was unmodified. You can use your e brake cable, you have leg room on the rear seat, etc.
I do steer away from cutting up or modifying my cars, speciually if they are street cars. Of course I would not do this to an original HEMI car, or an RT or something rare....because you are cutting and welding. But on all my "clone", "tribute" or modified cars I do this. Its a nice upgrade and you cant really tell they have been modified unless you really know how these cars look from, the underside from the factory.
I was thinking about offering these connectors already bent, trimmed and ready to install, along with the modified E brake brackets to go along with my torque boxes offerings....
What do you guys think?
Re: Subframe connector options and opinions [Re: domingo] #1161199
01/21/12 03:49 PM
01/21/12 03:49 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Domingo, nice work!
Now I suggest weld up the rest of the car. I can tell you that welding up it works wonders, esp underneath. Just be careful not to set the seam sealer on fire. The black n blue charger had a lot of welding underneath where it counts...and a fire.
Another overlooked area is a reinforcement across the package tray that is needed for those 5 pt seat belts and as another benefit stops all the flex across there. Go a step further and weld up the V brace as well. I think you can glue in the reinforcements as well with the correct glue.
Weld weld weld and weld some more.
If you weld up or glue enough of the car in the critical areas it will become enough of a true "unit" body and handle like a caged race car. The f-a-s-t race guys found the cars reacted better with a cage and no frame ties.
Now take it the rest of the way and put a bolt in "race brace" across the shock towers and back to the firewall and reinforce the stock braces in the wheel wells on the inner fenders. Weld the area where the uca mounts are welded to the car and weld up the shock towers and inner fenders. Don't forget a fully welded K frame. I am not sure the lower radiator brace is required bit it won't hurt either to weld that up.
Re: Subframe connector options and opinions [Re: domingo] #1161200
01/21/12 06:00 PM
01/21/12 06:00 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I think they look great, nice work.
Re: Subframe connector options and opinions [Re: boydsdodge] #1161201
01/21/12 07:14 PM
01/21/12 07:14 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Thanks for posting, Domingo. Great idea, great execution.
Re: Subframe connector options and opinions [Re: domingo] #1161202
01/21/12 10:30 PM
01/21/12 10:30 PM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
I agree those are about the best I've seen, but your building the car. Frankenduster's car is painted underneath and I was just trying to minimize the on car welding. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Subframe connector options and opinions [Re: ThermoQuad] #1161203
01/21/12 10:42 PM
01/21/12 10:42 PM
Here
jcc Offline
jcc  Offline
Here
, is that comparing a car with a cage and no frames ties, with a car just with just frame ties, or is that comparing car with a cage and no frame ties to a car with a cage and frame ties?
Still interesting comment regardless.
Re: Subframe connector options and opinions [Re: jcc] #1161204
01/21/12 11:49 PM
01/21/12 11:49 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I went with the us car tool frame ties. They each required an hour or so to get the fit right. Every floor pan is slightly different. I slotted the sides for e-brake cable routing. No other mods needed. Not sure on how the brake and fuel lines are going to fit. Very tight clearance. Here are a few pics.
Re: Subframe connector options and opinions [Re: NITROUSN] #1161205
01/21/12 11:49 PM
01/21/12 11:49 PM
N
NITROUSN Offline
NITROUSN  Offline
N
2
Re: Subframe connector options and opinions [Re: Kern Dog] #1161206
01/21/12 11:50 PM
01/21/12 11:50 PM
N
NITROUSN Offline
NITROUSN  Offline
N
3
Re: Subframe connector options and opinions [Re: Kern Dog] #1161207
01/21/12 11:50 PM
01/21/12 11:50 PM
N
NITROUSN Offline
NITROUSN  Offline
N
