MP P4532857 heads #1160871
01/19/12 06:49 PM
01/19/12 06:49 PM
Gainesville,FL
goldmember Offline OP
Gainesville,FL
Can anyone give me some info. I have a pr of heads with the P4532857 and cannot find any info. The previous owner states they are a stage VI head and use .485 offset intake rockers. Is this correct? Thanks
Re: MP P4532857 heads [Re: goldmember] #1160872
01/20/12 09:33 AM
01/20/12 09:33 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Are you sure the number is correct? I have heads with casting number P4532657, and they fit your description, they also have maxwedge intake ports and angled plugs.
Re: MP P4532857 heads [Re: goldmember] #1160873
01/20/12 09:40 AM
01/20/12 09:40 AM
tboomer Online work
tboomer  Online Work
Here is a link to some part numbers. It is down towards the bottom of the page..
http://www.moparts.org/Tech/Archive/bb/33.html
Re: MP P4532857 heads [Re: goldmember] #1160874
01/20/12 01:05 PM
01/20/12 01:05 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Yes, that is correct. I too have a spare set.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: MP P4532857 heads [Re: goldmember] #1160875
01/20/12 02:16 PM
01/20/12 02:16 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
If you need the .485 offset intake rockers for those heads check out the clearance section on the 440source web site. There were some of the old Mopar Perf rockers on there the last time I looked.
