T & D ROCKER STUDS #1160772
01/19/12 04:06 PM
01/19/12 04:06 PM
nc
E
earthmover Offline OP
E
nc
the rockers has 4 long studs and the rest or short ..i think the long studs go in the front and end holes on the -1 heads cause the holes are deeper then the rest..is this correct??????just starting to get my motor put back tog. and would like to make sure before i mess something up by not asking...thanks mike
Re: T & D ROCKER STUDS [Re: earthmover] #1160773
01/19/12 04:15 PM
01/19/12 04:15 PM
The long studs go in the end holes for oiling the rocker shafts
Re: T & D ROCKER STUDS [Re: Cab_Burge] #1160774
01/19/12 10:45 PM
01/19/12 10:45 PM
nc
E
E
nc
thanks cab
