What kind of caulking to use under Dutchmen panel? #1159837
01/18/12 12:05 AM
01/18/12 12:05 AM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
What is the proper type of caulking to use when installing a new Dutchmen panel on a 69 charger.
I noticed that on the top of the panel that goes below the Dutchman that there were 2 strips of caulking that the Dutchmen sits on once welded in.
Thanks!
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: What kind of caulking to use under Dutchmen panel? [Re: 69charger440_6pa] #1159838
01/19/12 02:11 AM
01/19/12 02:11 AM
Oakley CA
Oakley CA
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: What kind of caulking to use under Dutchmen panel? [Re: 69charger440_6pa] #1159839
01/19/12 09:39 AM
01/19/12 09:39 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
I can't really help other than to say I just removed my dutchman panel last night on my '69 Roadrunner and didn't see any caulking at all, but mine was really rusty. When I use caulking I get mine from Eastwood. They have it in a tube or a can for brushing on.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: What kind of caulking to use under Dutchmen panel? [Re: 69charger440_6pa] #1159840
01/19/12 01:11 PM
01/19/12 01:11 PM
michigan
Sparky77 Offline
Sparky77  Offline
michigan
dont know the part # but 3m makes a brushable seam sealer should be able to buy it at any body supply store
Re: What kind of caulking to use under Dutchmen panel? [Re: Sparky77] #1159841
01/22/12 11:02 AM
01/22/12 11:02 AM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
I have used many Eastwood products and have not been impressed. I did do some research into caulking body panels and tried a few brands. I like this the best. Fuser from Lords. It looks like the original, the tube lets you force the caulk into seams, then you can still brush the top for the factory finish.
