Re: Bushings for A bodies, whats best?
[Re: jcc]
#1159805
01/18/12 01:23 AM
01/18/12 01:23 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Firm Feel is where to get LCA bushings and some greasable LCA pins. Id skip the rubber.
Mopar to the bone!!!
[Re: jcc]
#1159806
01/18/12 01:39 AM
01/18/12 01:39 AM
Posts: 4,442 Texas
Daty Rogers
World's Greatest Husband. I love you Robyn
Texas
Rubber lca bushings are preferred(don't think poly is even available anymore). -Daty
"preferred" or accepted? And what about "delrin" LCA bushings?
Poly lcas failed miserabibly. Great idea, wore out too quickly, Don't know about delrin, it came out about the same time I built my front end. A little gunshy, rubber worked great for me, just don't tighten it before you get it on the ground. As far as handling, rubber below, Moog offset up top on stock lca's you're golden. Wish Moog made poly for the top, that would have worked very well, less movement.
-Daty
[Re: 72Swinger]
#1159807
01/20/12 05:36 PM
01/20/12 05:36 PM
Posts: 369 California, USA!!!
WheelsUp73
California, USA!!!
Exactly. We went with upper aftermarket arms with heimjoints and the firmfeel nylon lower bushing and their greasable pins,also installed solid mounted strut rods. Car drives awesome now. Rubber deflects too much. Here is a video of my car comming down from a 150 foot wheelstand.Tires are very stable at landing. http://youtu.be/LWD9sbw_UWk
[Re: Daty Rogers]
#1159808
01/20/12 06:49 PM
01/20/12 06:49 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
-Daty
I have the same Poly LCA bushing I put on in 1997. We looked at them last year when we put the Hotchkis TVS stuff on and Hotchkis said just reuse them. And there were new poly LCA bushings setting right there in thier kit we didn't use.
. . . Now...I had a horrible time making the Mopar poly LCA bushings fit to "what I thought was right" in 1997.
They did not want to press in by hand with a lot of force. I had to turn down the OD of the poly bushing and polished and enlarged the ID of the old rubber bushing casing.
I also polished the LCA pin shaft too. Then all of that was slather with that special snotty translucent poly bushing grease they give you. I actually bought a seperate mini container of that grease.
IMHO, I bet a lot of people don't go to that effort to get the poly LCA to fit right if they have issues like or near what I did. I also know people that didn't have any ploblems slipping the bushing in. I believe that is because different manufactures of rubber LCA bushings might have different metal casing thinknesses. Also they are not designed to have the ID of the casing as a critical dimension. But when we put poly bushing in there it becomes critical.
Energy Suspension now sells complete poly bushing assemblies for most all applications with metal casings and all(excect Mopar LCA's). BUT before that you had bear poly bushings to put in the old rubber casings.
In about 1988 Dick Guldstand had those bare poly bushing like that for all Corvette, Camero, and GM A-body applications. I remember installing them in our GM A-body racecar that my High School shop teacher had. But a couple of years later Guldstand totally sold Energy kits. They said so many people had issues fitting the bare bushings that they switched to selling all Energy stuff where they could.
[Re: autoxcuda]
#1159809
01/20/12 06:56 PM
01/20/12 06:56 PM
WheelsUp73
California, USA!!!
-Daty
I have the same Poly LCA bushing I put on in 1997. We looked at them last year when we put the Hotchkis TVS stuff on and Hotchkis said just reuse them. And there were poly LCA bushing in thier kit.
[image][/image]
On the bushing fitting the shell, we honed the shell till the bushing fit snug. The hole in that shell is nowhere close to being round and the honing helped true up the hole.The lower arm pivots nice and free now.
[Re: WheelsUp73]
#1159810
01/20/12 07:03 PM
01/20/12 07:03 PM
autoxcuda
So Cal
So even with the Firm Feel nylon/delin bushings you still had to fit the old rubber bushing shell to get a nice free running bearing movement.
Sorry, I edited and added above about my little history with those type of bushings.
[Re: autoxcuda]
#1159811
01/20/12 07:14 PM
01/20/12 07:14 PM
WheelsUp73
California, USA!!!
Yes we did it was worth the extra time spent.
[Re: WheelsUp73]
#1159812
01/20/12 07:43 PM
01/20/12 07:43 PM
72Swinger
Nebraska
Your wife ain't scared^^^^^! I've seen those vids of her shifting mid wheelie Awesome! I used Firm Feel greasable pins with no inner shell and the stock outer shell with Energy bushings. Tight yet free movement.
[Re: 72Swinger]
#1159813
01/20/12 07:52 PM
01/20/12 07:52 PM
WheelsUp73
California, USA!!!
No I'm not scared. LOL Its dissapointing if it don't carry the wheels at least 100 feet.:) Here is a new pic of the back of the car. My husband was the scared one watching those big wheelies from outside the car. You can see in the pic where it use to drag on the ground. http://i177.photobucket.com/albums/w203/slcalddrag/DSCN0185.jpg
[Re: NV69B7RR]
#1159817
01/21/12 05:34 AM
01/21/12 05:34 AM
Posts: 4,442 Texas
Daty Rogers
Texas
Thanks Daty!
What about the rear leaf spring bushings?
I used rubber back there, have no problems with it. I did use new ones though.
-Daty
