Re: Testing a neutral safety switch?
[Re: vdriver]
#1158992
01/16/12 11:29 PM
01/16/12 11:29 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I'm pretty sure that in P and N the neutral safety should be at ground. I know that if you jump the neutral safety connection on your starter relay to ground, your car will start in any gear. Hope that helps.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: vdriver]
#1158993
01/16/12 11:34 PM
01/16/12 11:34 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
In park or neutral center pin has continuity to ground In reverse outer pins have continuity to each other... Btw the little metal dot in the center of the plastic button actually grounds through the shifter comb... That is why if you look at the comb there are two metal lines through the plastic comb..
