RB Crane ductile rocker arm questions... #115894
09/06/08 07:11 AM
09/06/08 07:11 AM
MA
440beeper Offline OP
MA
What do you guys recommend for shafts/hold-downs for Crane ductile rocker arms? Thinking of going with 440source's hold-downs, but not sure if these (MP) type hold-downs work with these rockers. Someone told me you also need banana grooved shafts for these rockers...yes/no?? This is for a street car with a mild street/strip solid cam. Thanks
Re: RB Crane ductile rocker arm questions... [Re: 440beeper] #115895
09/06/08 01:18 PM
09/06/08 01:18 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Bannana shafts are highly recommended though plenty are running without them...I'm running a set..
I have the 440 source hold downs on my Isky ductile iron rockers, they are fine but make sure you use a steel rocker shim between the holdown & the rocker arm...Mine actually required about .060 worth of shims to properly center the arm on the valve stem...
