Page 1 of 3 1 2 3
trans fluid for A-518 #1158659
01/16/12 05:07 PM
01/16/12 05:07 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
Got a non lock up A-518 and am trying to decide wich atf to run, i wanted to run atf+4 originally but the guy who re-built my transmission told me that atf+4 has alot of friction modifyers that my transmission does not need because i have no converter clutch.
I have always been told that type f is the best atf to run in a torque flight, my old man ran type f in the 727 in his 70 plymouth cuda 440-6 pak car and in his 77 dodge truck and had great results, he always told me that you want a firm shift not a sloppy shift.
I realize the A-518 has an overdrive unit so it is not exactly the same as a 727 but they are very simliar, is there any reason type f would perform any different in a non lock up A-518 as it does in the 727?
I was considering the valvoline max life atf, but the owner of the transmission shop who re-built my transmission told me to stay away from synthetics and type f, in fact he said anyone who runs type f in a torque flight is an idiot... wich i had to strongly disagree, my old man ran type f in them and he was the smartest mopar guy i knew, unfortunetly he has passed away so i can not ask him bout running type f in the non lock up A-518. The owner of the transmission shop told me to run ether dexronIII or atf+3 or a non synthetic universal fluid, wich is what i think they put in my transmission.
So what fluid do i use? i have a good sized transmission fluid cooler mounted on outside of my raditor and i plan on getting a transgo shift kit installed, with that being said should i run dexronIII, type f. or valvoline max life even tho max life is a synthetic and my builder told me not to use a synthetic atf? i dont know why he said no to synthetics he didnt explain himself on that he just said no synthetics no type f no +4 and said if you can still find +3 you can use that, if not put a non synthetic universal fluid in it or dexronIII and call it good.
He told me to flush all the fluid out and change the filter and fill up with new fluid after 1000 miles, i am currently at 600 sum miles, so its coming up and i need to pick a fluid to run, thanks
Re: trans fluid for A-518 [Re: pjc360] #1158660
01/16/12 05:59 PM
01/16/12 05:59 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If you have a warranty and want it honored I would run what the builder specifies .
I run dexron III in my lockup 47RE , over 100k miles without an issue .
Re: trans fluid for A-518 [Re: pjc360] #1158661
01/16/12 06:03 PM
01/16/12 06:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Type F lacks the lubricating properties needed for the overdrive. Dexron/Mercon would be appropriate for a non-lockup 518.
Re: trans fluid for A-518 [Re: John_Kunkel] #1158662
01/16/12 07:49 PM
01/16/12 07:49 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have always ran type-f in my re-built trannys for my self and customers and have not had one come back. I do always drill holes for extra lube to the OD mabey that is why or mabey I am lucky I probably just do one t-flite a month, Mr, Kunkle on the other hand I think does a lot more I am always willing to learn a little something...
Re: trans fluid for A-518 [Re: HotRodDave] #1158663
01/17/12 03:15 AM
01/17/12 03:15 AM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
what lubricating properties are need for the overdrive? and since lubrication is important for the overdrive should i be considering a fluid like the valvoline max life atf? i wanted to run the max life atf and had my mind pretty much made up over it untill the owner of the transmission shop who re-built my A-518 told me to stay away from synthetic atf's.
I really wish i knew why he does not want me to run a synthetic atf, he didnt really explain himself on that he just said stay away from synthetics, is synthetic atf's a bad idea for my transmission? or can and should i use the max life, or should i just run regular dexronIII because thats what he says to run? i would like the added protection of the synthetic if thats an important thing in the overdrives wich it sounds like it is. but i would also like firmer shifts, would the max life atf cause softer shifts then reg dexronIII or would they be close enough to where a person couldnt tell?
Re: trans fluid for A-518 [Re: pjc360] #1158664
01/17/12 12:54 PM
01/17/12 12:54 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I don't know the builder's reasoning behind 'no synthetic'.
What I do is use ATF+4. Reason is simple, I have 4, soon to be more with autos. I'd rather have a stock of one type of fluid.
Re: trans fluid for A-518 [Re: pjc360] #1158665
01/17/12 12:56 PM
01/17/12 12:56 PM
JohnRR Offline
JohnRR  Offline
This is your answer .
Re: trans fluid for A-518 [Re: JohnRR] #1158666
01/17/12 01:28 PM
01/17/12 01:28 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the problem with the synthetics and +4 is they are all desighned with lots of friction modifiers, those modifiers make the clutches slip when they engage. Slipping clutches makes for softer shifts so the manufactures are useing it to make softer shifts because softer shifts sell cars. On the other hand slipping clutches also mean burning clutches especially at elevated power levals. Type-F has the highest friction and helps the clutches grab faster and slip less. It is somewhat of a trade off because the pistons, gears, bearings and valves will see less wear from higher friction. In my experiance the best trade off is to make the clutches last longer and increase lube to mechanical stuff through minor mods in the fluid flow circuits.
Re: trans fluid for A-518 [Re: HotRodDave] #1158667
01/17/12 09:15 PM
01/17/12 09:15 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
Thats why im on the fence about using type f or dexronIII, somone said type f lacks the lubricating properties needed for the overdroive unit, i want the protection needed for the overdrive, what does dexronIII have that type f does not have?
Type f is what i'd like to run for reasons stated above, the firmer shifting and less slipping of the clutches, but if something happened to my transmission i would not want the transmission shop to deny my warranty due to running type f when they told me not to. I dont see how they would know what fluid is in the transmission, they would have to send it away to get tested im guessing and im sure that wouldnt cheap? price wise the dexron/merconIII is same price as the type f but i think the type f is a little cheaper, and is there a difference between type f and type fa?
Re: trans fluid for A-518 [Re: HotRodDave] #1158668
01/17/12 09:28 PM
01/17/12 09:28 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
if you wieght the pro's and con's to the two fluids its still a tuff choice between the two.
Pro's to the type f, firmer shifts, clutches will last longer with type f and i am told f is excellent against heat. con's to the type f, it lacks the lubricating properties for the overdrive unit, the additives in it die quicker then in the dexronIII and my builder advised against using it.
Prp's to the dexronIII, it is what my builder reccomends using, it does have the lubricating properties needed for the overdrive and the additives last longer meaning the fluid will last a longer, Con's to the dexronIII it has friction modifyers in it, it will cause transmission to shift softer then type f therefore wearing clutches out faster.
so you see after wieghing the pro's and con's its still a tuff choice between the two.
Re: trans fluid for A-518 [Re: pjc360] #1158669
01/17/12 09:31 PM
01/17/12 09:31 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Does anyone know where ATF 4 is available in gallons or maybe even a 5 GALLON PAIL?
Re: trans fluid for A-518 [Re: dOc !] #1158670
01/17/12 10:04 PM
01/17/12 10:04 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
i'm sure you could order a 5 gallon pail of atf+4 from your local parts store, like napa or car quest or oreilly auto parts. in fact i seen big pails of different atf's on oreilly auto parts website.
Re: trans fluid for A-518 [Re: pjc360] #1158671
01/17/12 10:25 PM
01/17/12 10:25 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
At this point i'm thinking m just going to flip a coin heads for type f tails for dexronIII, weighed the pro's and con's to each and they both have there good and bad points, but like a previous poster said, increasing clutch life sounds most important to me as well, and if type f helps increase the clutch life, then thats the fluid to run in my opinion, just wish my builder would agree because him telling me not to run type f is the only reason i have not chosen it
Re: trans fluid for A-518 [Re: pjc360] #1158672
01/17/12 11:30 PM
01/17/12 11:30 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Most of the bad overdrives I have seen it was bad clutches not hard parts although I have seen one of the big roller bearings in the back go bad and one set of planataries go bad in one. I run type-f in my personal stuff and tow with the OD all the time
Dexron III is close but not quite as slippery as mopar +4.
Either way you choose I don't think it is a huge differance, I just like giving mine the extra little edge and yes, you can feel the differance in going from +4 to type-F while dexron III will be in the middle.
Re: trans fluid for A-518 [Re: pjc360] #1158673
01/18/12 12:02 AM
01/18/12 12:02 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
do not run royal purple or redline there synthetics are too slipery for puter trans, if you can find +3 from a dodge dealer that would be the best, if not cheapest +4. if you run dextron III you must use with +4 additive also found at dodge dealer.
MOPAR OR NO CAR
Re: trans fluid for A-518 [Re: hemigod426] #1158674
01/18/12 01:27 AM
01/18/12 01:27 AM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
My transmission is not electronically controlled, it's a 1991 and is still hydraulically ran, with a non lock up converter. hotroddave, have you ever ran type f in a non lock up A-518? you say you run in it yur transmissions, was just curious if you have a non lock up A-518 like mine and if you have ran type f in it? if so how does it perform? is it any different then how it performs in a regular 727? i wouldnt think there should be any reason for it to perform any differnt in the non lock up A-518s then in the 727s.
And i agree keeping the clutches in optimal sounds like the best idea to me as well. i dont see why type f wouldnt be able to lubricte the bearings and planatery gears an different then dexronIII or atf+4 does.
Re: trans fluid for A-518 [Re: pjc360] #1158675
01/18/12 01:36 AM
01/18/12 01:36 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have ran it in one non-lock-up 518 (non a lot of them out there)and it was behind a very serious SB stroker and that was like 6 years ago and it is still working fine. I run it in my 97 46RE (electronic 518) and it is fine.
Re: trans fluid for A-518 [Re: HotRodDave] #1158676
01/18/12 07:33 PM
01/18/12 07:33 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
that's what i figured, i couldnt see any reason for type f to work any different in a non lock up A-518 then how it works in a 727, that's the fluid im leaning twords using the most. I will most likely use it, is there a difference between type f and type fa?
Re: trans fluid for A-518 [Re: pjc360] #1158677
01/18/12 07:55 PM
01/18/12 07:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's the difference, the planetaries in the 727 are only running in the first two gears and can survive without much lube. The 518 planetaries are running almost constantly and need better lubrication.
Those who are sucessfully running type F in OD transmissions illustrate the old adage..."There's a difference between doing it right and doing it wrong and getting away with it".
As stated earlier ATF+4 is formulated for lockup converter clutches, not needed in a non-lockup 518 but it won't do any harm if you're not making tons of power.
Re: trans fluid for A-518 [Re: John_Kunkel] #1158678
01/18/12 08:00 PM
01/18/12 08:00 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
It's Swifty! Swifty, you toad sucker!
Page 1 of 3 1 2 3
