Reusing Cometics
#1158491
01/16/12 10:35 AM
01/16/12 10:35 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
If your going to reuse Cometics, should you resurface your aluminum heads or is that not necessary?
Anyone had issue trying to reuse Cometics?
I don't feel any grooves or indention in the heads caused from the Cometics so I guess it just flatens out the raised sealing rings on the Cometics (I was mistakingly thinking it would leave grooves in the heads like when you O-ring the block).
I've got both of my motors apart (Abbey's and mine), her Cometics are new from last year. Mine are about 3 years old.
Not sure I really want to take a chance but considering it so I wanted to get some opinions from you guys.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Reusing Cometics
[Re: Big Squeeze]
#1158493
01/16/12 11:23 AM
01/16/12 11:23 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Just clean the gaskets and heads and bolt it back together......
and make sure they go back on with the same orientation that they came off. I'm on my 3rd reuse. No spray copper or any sealers, just bolted on
I like the ability reuse gaskets and that's why I chose the materials that I use to make my gaskets with
[Re: Irun5snd8th]
#1158495
01/16/12 01:26 PM
01/16/12 01:26 PM
Posts: 4,075 Mo.
racerx
Mo.
I spray mine with copper but I have reused a set 4 times at over 12:1 compression on alcohol
y the copper spray just curious?
[Re: WadeMetzinger]
#1158496
01/16/12 01:43 PM
01/16/12 01:43 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
I reuse them 3 times. Clean the block/heads and the surface of the gasket. Some people drill out the rivets and clean between the individual gaskets but I do not. I wipe them down with thinner which removes what's left of the factory rubber coating, then give them a light spray with copper gasket sealer to seal the water passages and back on they go.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: Big Squeeze]
#1158497
01/16/12 02:39 PM
01/16/12 02:39 PM
Posts: 914 tn
robnbird
tn
do not use a cleaner like carburetor cleaner to clean the gasket. most gaskets have a very thin layer of silicon on the outer surface of the gaskets and some cleaners will wrinkle the sealer.
[Re: WadeMetzinger]
#1158499
01/16/12 03:36 PM
01/16/12 03:36 PM
Posts: 1,611 westerly, ri. usa
440lebaron
westerly, ri. usa
hello, anyone want to buy a set for .060 over 440 .049 thick, i will not reused them. pm me gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#1158500
01/16/12 04:35 PM
01/16/12 04:35 PM
roadhazard
Akron, Ohio U.S.A.
Sure......do "your" heads and block come with them
[Re: roadhazard]
#1158501
01/16/12 05:37 PM
01/16/12 05:37 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
You make head gaskets?
[Re: POS Dakota]
#1158503
01/16/12 06:20 PM
01/16/12 06:20 PM
roadhazard
Akron, Ohio U.S.A.
No Sir, Just the soft gaskets like valve cover, intake, oil pan, timing cover, etc, etc.
[Re: Irun5snd8th]
#1158504
01/17/12 12:10 PM
01/17/12 12:10 PM
Posts: 4,075 Mo.
racerx
Mo.
My deck surface does not meet the smoothness criteria for the gasket. If I dont use the copper they seep water to the outside. That and I wouldnt chance it anyway. Too much trouble to take back apart to save myself 5 minutes of spraying.
I understand now Thax.......
[Re: racerx]
#1158505
01/17/12 02:23 PM
01/17/12 02:23 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Just to let everyone know, I usually use my Cometics several times without issues,spraying them with coppercoat just as insurance. This year after 3 uses I decided to replace them just as a regular part of my refreshening my motor. I ordered the Mr. Gasket ones which are supposed to be just repackaged Cometics. The packaging specifically say's to "NOT COAT the gaskets,just clean and bolt on. I decided that I was gona spray them anyway cuz I always do!!! I don't know if they just changed things or what but the surface of the gaskets are now kind of shiny and will not accept a spray of coppercoat. After drying it easily comes off even with gentle handling!(I did clean them first) So I installed them with out any coppercoat this year for the first time and will keep my fingers crossed and hope for the best. Mike
[Re: 70satelliteguy]
#1158506
01/17/12 03:00 PM
01/17/12 03:00 PM
Posts: 13,390 Marion, South Carolina [><]
an8sec70cuda
The Cometics also say not to use any coating/spray on them, but myself and everyone I know spray them w/ coppercoat.
