brake hoses source and options?
#1158122
01/15/12 07:17 PM
01/15/12 07:17 PM
Posts: 1,216 Fresno, CA
cudamank
Fresno, CA
I need to replace the rear brake hose on my car, it is after all 42 years old and has developed a leak. Looking for options and sources. None of my local stores carries the rubber lines, and wondering if I should upgrade to a stainless flex line. Suggestions?
Remember remember the 11th of September, of murder and a terriosts plot. I see no reason why this treachery should ever be forgot.
Re: brake hoses source and options?
[Re: cudamank]
#1158123
01/15/12 08:28 PM
01/15/12 08:28 PM
Really?
I got the one for my '63 at O'Reilly's.
I had to ask for a '70 Charger IIRC.
[Re: TooMany62s]
#1158125
01/15/12 09:50 PM
01/15/12 09:50 PM
Posts: 3,344 Central TX
roe
Central TX
I've always had great.luck with Autozone.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: TooMany62s]
#1158128
01/16/12 06:42 PM
01/16/12 06:42 PM
cudamank
Fresno, CA
What's the application?
that is an excellent question.
70 plymouth Cuda' Rear brake hose.
Sorry thought I had put that in my original post.
[Re: TooMany62s]
#1158132
01/16/12 09:14 PM
01/16/12 09:14 PM
Posts: 1,792 Greer, SC
TooMany62s
Greer, SC
Or try looking up this one on Rockauto.com:
BH36648
[Re: burdar]
#1158133
01/16/12 09:24 PM
01/16/12 09:24 PM
Posts: 15,487 Florida
scratchnfotraction
There was a post about this before. It was said that in 1970 the rear brake hose screws into the T on the rear axle. Other years have the hose crimped onto the T. I know the parts stores carry the later crimped style but not the 1970 one. I don't know if the later year style will work for you or not.
this is a screw in hose on a 3 port brass block with vent bolt from a 67 polara 8 3/4 IIRC
does it look like yours on the 70?
