Big Block Exhaust Manifold to Head Pipe Bolts
#1158079
01/15/12 06:59 PM
01/15/12 06:59 PM
Posts: 1,893 Sault Ste. Marie, Ontario, Can...
moparmike1
Hi,
I'm trying to remove the two bolts that hold the head pipe to the exhaust manifold, this is 400. I've got both bolts spinning and my plan was to put a wrench on the top of the bolt, keep turning the nut from below until the wrench jams against the block and keep turning until it comes off. But, there's not enough space around the bolt's head to put a wrench around it. The manifold flanges up around the bolt head.
I'm sure the easy way is to torch off the nuts but I don't have access to torches and the car isn't mobile so bringing it to a shop isn't an option.
If anyone has any other suggestions, I'd appreciate it.
Thanks,
Mike.
Re: Big Block Exhaust Manifold to Head Pipe Bolts
[Re: moparmike1]
#1158080
01/15/12 07:26 PM
01/15/12 07:26 PM
Posts: 3,344 Central TX
roe
Central TX
I have a little dremmel with a cut off disc that is great for tight spaces and makes quick work of stuff like this. With the different tips they are great for small cutting and grinding jobs.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
