Re: 440 vs 440 magnum
[Re: B5 Bee]
#1158069
01/15/12 08:16 PM
01/15/12 08:16 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
Magnum, Super Commando, TNT, will have; higher compression cam with more duration and lift windage tray baffled oil pan free flow exhaust manifolds larger carb different ignition curve motors in front of manual trans had dual points
depending on year, it could also have; larger exhaust valves higher capacity oil pan
Higher compression will also depend on the year , 66-70 the 350HP and 375HP motors had the same advertised compression ratio.
[Re: B5 Bee]
#1158070
01/15/12 08:18 PM
01/15/12 08:18 PM
Posts: 3,920 n.e. pa.
65rbdodge
n.e. pa.
+valve springs
[Re: DaytonaTurbo]
#1158072
01/17/12 03:32 PM
01/17/12 03:32 PM
dogdays
UHHHHH, I don't think so. HP pistons should have a taller compression distance to raise compression, at least til '73 or so. Also the 908 "6-pack" rods were in the HP motors for a while. R.
