Sway bars #1157973
01/15/12 03:51 PM
01/15/12 03:51 PM
SC
72 RR Rick Offline OP
SC
Will an aftermarket sway bar work with factory brkts. on lower cont. arms? Thanks Rick.
Re: Sway bars [Re: 72 RR Rick] #1157974
01/15/12 04:22 PM
01/15/12 04:22 PM
SC
SC
BTTT.
Re: Sway bars [Re: 72 RR Rick] #1157975
01/15/12 04:27 PM
01/15/12 04:27 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Most of the times yes.
What aftermarket sway bar is it. Best bet is to measure it eye to eye and check that distance against original.
Re: Sway bars [Re: 72 RR Rick] #1157976
01/15/12 04:39 PM
01/15/12 04:39 PM
AndyF Offline
AndyF  Offline
The good ones will but the el cheapo stuff might not.
Talk to the guys at Firm Feel, they can get you a bar that works with your stock mounts.
