What does this hook up to? Fuel vent line..
#1157617
01/15/12 02:00 AM
01/15/12 02:00 AM
Posts: 297 Oklahoma
TinCuda
Oklahoma
OK, guys. I need your help again. After I got my car back from paint, I pulled the tape off this tube and forgot what it hooks up to. If there is a part missing in the picture, I am sure I have it, just need to know what it looks like.
1971 Plymouth 'Cuda right back engine well.
Thanks.
(O O {]{]{]||[}[}[} O O)
1971 Plymouth 'Cuda 440-6
{||O||}
2000 Yamaha V-Max
(O O [========= SRT] O O)
2011 Dodge Challenger SRT 392
Making as big as a carbon footprint as I can!!!
Re: What does this hook up to? Fuel vent line..
[Re: TinCuda]
#1157618
01/15/12 07:02 AM
01/15/12 07:02 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
on my old 71 RR there was a hose that hooked to the bowl vent on the carb. It would work good for a retune line for a regulated system.
I am truckless..
[Re: 72roadrunnergtx]
#1157621
01/16/12 01:10 AM
01/16/12 01:10 AM
Posts: 75,087 A Banana Republic near you.
JohnRR
That’s the fuel tank vent line, in 71’ it was connected to the crankcase breather cap on the right valve cover. A larger hose from the carb bowl vent valve would have it’s own nipple on the breather cap as well.
, it's not a return for a fuel pump ...
[Re: TinCuda]
#1157623
01/16/12 02:06 AM
01/16/12 02:06 AM
Posts: 297 Oklahoma
TinCuda
Oklahoma
Or better yet, if I run the carb bowl overflow to the tube?
{||O||}
2000 Yamaha V-Max
[Re: TinCuda]
#1157624
01/16/12 06:09 AM
01/16/12 06:09 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
If you cap it, you will be eliminating your fuel tank vent. You will then be creating a vacuum in your tank as you drive the car and the fuel level lowers, which can cause vapor lock, and can also cause the tank to slightly flex as the vacuum becomes stronger. I had my Cuda set up like this for a while, and when I would take the gas cap off to refuel you could hear a "woooosh" as the air rushed back into the tank through filler tube, and you could also hear the tank flexing back into it's original position. But, if you do plug the line, a vented gas cap is all you need to solve this problem - that's what I ended up doing.
You could also just make some kind of a small breather/filter for the end of the line to keep crud from getting in it, and leave it as-is. As long as the filter doesn't block air from flowing in and out of the line, you should be fine, and the line will remain as a tank vent.
Connecting it to the carb vent may work fine, but I'm not sure. It may work fine as far as venting the tank, but the carb may not like it. You might be creating another problem to solve the first. My guess is that you would be connecting two things together that both need to be vented, but not have an actual vent for either one, giving you two problems instead of one.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
[Re: Challenger 1]
#1157626
01/18/12 06:35 AM
01/18/12 06:35 AM
Posts: 297 Oklahoma
TinCuda
Oklahoma
So, can someone point me in the right direction on where I can buy a three port valve cover breather? I would like to stay away from ebay. I am buying parts as I go over time. I may not be able to buy it now.
{||O||}
2000 Yamaha V-Max
[Re: TinCuda]
#1157627
01/18/12 08:25 AM
01/18/12 08:25 AM
Posts: 297 Oklahoma
TinCuda
Oklahoma
On the flip side, what would be wrong with a couple of creatively placed T-fittings so I could use a one port breather. The three lines all go to the same place anyway right?
{||O||}
2000 Yamaha V-Max
[Re: TinCuda]
#1157628
01/18/12 11:13 AM
01/18/12 11:13 AM
Challenger 1
Cincinnati, Ohio
Nothing wrong with that idea, imo.
