Re: 8 1/4" axle vent tube?
[Re: mopars4ever]
#1157473
01/15/12 01:04 AM
01/15/12 01:04 AM
Posts: 13,613 md
mopars4ever
md
[Re: Not_A_Blazer]
#1157476
01/16/12 08:12 PM
01/16/12 08:12 PM
Posts: 15,487 Florida
scratchnfotraction
your wanting a vent/brakeline tee bolt like 8 3/4s use. if I understand what you asking. I think you could convert that over with the 3-port brass block/vent bolt from a 8 3/4. you may have to change the rubber line from the frame hard line to the brass block port. i will see if I can dig up the line/block vent bolt i have for pics. after re-reading..i think you just need the vent bolt from an 8 3/4
[Re: scratchnfotraction]
#1157480
01/28/12 10:53 PM
01/28/12 10:53 PM
Posts: 1,137 Lemont, IL
Not_A_Blazer
super gas
super gas
Lemont, IL
Thanks for the pics,I ended up going to the shed and the '55 stock rear that I took out of the truck had the same style vent tube,and was also the same pipe thread!
