Re: any one using 383's to race
[Re: Defbob]
#1156662
01/14/12 02:08 PM
01/14/12 02:08 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Ran one with old TRW 12.5's, steel rods, 312 heads with bigger valves, a Hughes .600" solid lifter cam, a tunnel ram with a pair of Ron's 4-shooters on top. Ran 9.50 @ 149 like clockwork.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: blue_stocker]
#1156663
01/14/12 03:20 PM
01/14/12 03:20 PM
Posts: 80 tampa florida
1badrt
tampa florida
thanks for the info, you guy's are awesome,
[Re: HYPER8oSoNic]
#1156665
01/14/12 05:32 PM
01/14/12 05:32 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Ran one in an all steel 68 Cuda. Had ported 906's and stock pistons and bore. Heads were cut to up comp to 10.5. Had the MP .557 cam and the TM6 intake with a 700 DP. With a TA 3800 series converter and 4.56's it ran 11.40's @ 118. Ron
[Re: 68roadrunner]
#1156673
03/01/12 11:08 PM
03/01/12 11:08 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
the question is who has the most hp 383 block, especially na, but adders is cool to.
383 block only?
probably some guy with a stroker pushing close to 500 cubic inches and nearly 800 hp.
unless someone has a hard fill, main girdle, etc.
if I was going to build a stock stroke 383, it would be an RPM motor with big heads, light rods and pistons, and I'd spin it 7500 or 8000, or however much RPM I could get stable valve train out of.
but for a fun street driver, I think the stroker I put into my 383 is just about perfect! 505 hp, 535 torque flywheel numbers, with a broad flat torque "curve" only thing I'd do different, is some port work on the Eddy heads and maybe a tad more cam and RPM to eek out closer to 550-600 hp. right now it maxes out right at 6,000 rpm.
**Photobucket sucks**
