Re: AFTER-MARKET ROD SUGGESTIONS?
[Re: Labratt]
#1156410
01/13/12 04:14 PM
01/13/12 04:14 PM
Posts: 2,091 Delray beach, Florida
Performance Only
we sell and use a lot of both the K-1 and Compstar rods. the Compstars cost just a few dollars more. both will get the job done. the Compstar is IMO a better overall rod.
machine shop owner and engine builder
[Re: Labratt]
#1156411
01/13/12 06:21 PM
01/13/12 06:21 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
[Re: AndyF]
#1156413
01/13/12 08:04 PM
01/13/12 08:04 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
K1's here
[Re: johnzgarage]
#1156415
01/13/12 09:58 PM
01/13/12 09:58 PM
Posts: 763 Southington Ct.
turbobitt
Southington Ct.
K1 gets my vote.
Get them from a supporting vendor like Performance Only since they done a lot of work with K1 to insure a quality product.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: jamesc]
#1156418
01/14/12 01:43 AM
01/14/12 01:43 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I have field tested eagle rods and can say they are tough.... Even over heated a few, cleaned them up honed them and put them back in use... Engine was making 700+ HP turning 7200 rpms I should note. They didnt even have the better bolts, just the 8740.. I put that engine through hell, in a street car for a good while, into several diff chassis in race only from 2004 to 2009 hundreds pass's in a single season. ![](/ubbthreads/images/graemlins/beer.gif)
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#1156419
01/14/12 01:47 AM
01/14/12 01:47 AM
Bob_Coomer
Rock Springs
In the budget rods your looking at, let me say you can save about 70-80 grams in the I-beam rod over the same spec H-beam... I have run the cheap RPM rods in a few engines, and they worked great... I found a guy on ebay selling rods for like $250 which are the same rods everyone else sells for hundreds more.... I would run these in a heart beat in a application like yours Randy... Just have them checked of coarse, never had a single problem yet, other than the small pin needs honed... Thats common procedure with these.... Shoot me a I will jump on the old computer and dig up that ebay link for ya... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Labratt]
#1156421
01/14/12 07:52 PM
01/14/12 07:52 PM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
Randy I had an opportunity to compare 5 different rods side by side before I chose the K-1 rods ![](/ubbthreads/images/graemlins/thumbs.gif) When I was checking them before assembly all eight were perfect except one pin bushing was slightly tight.Just a few seconds with some crocus cloth and perfect like the rest. Give Nick a call ![](/ubbthreads/images/graemlins/callme.gif) I think he has a few sets on the shelf but they may be for 990 pins ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) what size are your pins? Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
