AFTER-MARKET ROD SUGGESTIONS? #1156407
01/13/12 02:55 PM
01/13/12 02:55 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I'm dipping into my body-and-paint money to strengthen the lower-end on my 440...which I SHOULD have done back in 2005...when I had it re-built! I went with reconditioned,and bushed, LY factory rods,mated to Diamond forged pistons,and reconditioned factory forged crank. After getting the Eddy heads cnc-ported and milled .060,I'm estimating about 600-620 hp at the crank. I shift between 62-6500 rpm,and trap approx. 67-6800 in the 1/4. Please give me your suggestions. H-Beam or I-Beam? I'd like to keep the price to $500.00 or less. THANKS in advance! Randy B.
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Labratt] #1156408
01/13/12 03:01 PM
01/13/12 03:01 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Compstar would be my suggestion.
Keith
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Dunnuck Racing] #1156409
01/13/12 03:35 PM
01/13/12 03:35 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
K1 Billet's are close to that price. Get em with ARP2000 rod bolts. Tim
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Labratt] #1156410
01/13/12 04:14 PM
01/13/12 04:14 PM
Delray beach, Florida
P
Performance Only Offline
P
we sell and use a lot of both the K-1 and Compstar rods. the Compstars cost just a few dollars more. both will get the job done. the Compstar is IMO a better overall rod.
machine shop owner and engine builder
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Labratt] #1156411
01/13/12 06:21 PM
01/13/12 06:21 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Randy,
Check Pms.
RIP Monte Smith
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Labratt] #1156412
01/13/12 06:32 PM
01/13/12 06:32 PM
AndyF Offline
AndyF  Offline
Not a ton of choices for LY replacement rods anymore. You'll have to look around a bit to find them. Did you bush your LY rods down to the 0.990 pin size? If so, you'll have a few more options.
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: AndyF] #1156413
01/13/12 08:04 PM
01/13/12 08:04 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
K1's here
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Labratt] #1156414
01/13/12 08:44 PM
01/13/12 08:44 PM
saint paul mn.
johnzgarage Offline
johnzgarage  Offline
saint paul mn.
I think your opening a $500.00 can of worms. If you mess with the rods , you need to do do a rebalance. If you upgrade the rod bolts to some arp 2000 but, it wouldnt be worth it due to resizing the rod. I think the best bang for buck would be a stud girdle for your lower end. If you can, I would do both.
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: johnzgarage] #1156415
01/13/12 09:58 PM
01/13/12 09:58 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
K1 gets my vote.
Get them from a supporting vendor like Performance Only since they done a lot of work with K1 to insure a quality product.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: AndyF] #1156416
01/14/12 12:46 AM
01/14/12 12:46 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,guys! Andy..yes,they are bushed..with .990 pins.
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Labratt] #1156417
01/14/12 12:58 AM
01/14/12 12:58 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
it's a shame manley discontinued the sportsmaster rods. that was a quality forged in usa i beam rod.
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: jamesc] #1156418
01/14/12 01:43 AM
01/14/12 01:43 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I have field tested eagle rods and can say they are tough.... Even over heated a few, cleaned them up honed them and put them back in use... Engine was making 700+ HP turning 7200 rpms I should note. They didnt even have the better bolts, just the 8740..
I put that engine through hell, in a street car for a good while, into several diff chassis in race only from 2004 to 2009 hundreds pass's in a single season.
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Bob_Coomer] #1156419
01/14/12 01:47 AM
01/14/12 01:47 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
In the budget rods your looking at, let me say you can save about 70-80 grams in the I-beam rod over the same spec H-beam...
I have run the cheap RPM rods in a few engines, and they worked great...
I found a guy on ebay selling rods for like $250 which are the same rods everyone else sells for hundreds more....
I would run these in a heart beat in a application like yours Randy... Just have them checked of coarse, never had a single problem yet, other than the small pin needs honed...
Thats common procedure with these....
Shoot me a I will jump on the old computer and dig up that ebay link for ya...
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Bob_Coomer] #1156420
01/14/12 10:32 AM
01/14/12 10:32 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Bob! Please PM the link..I'll check them out for sure! Randy
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Labratt] #1156421
01/14/12 07:52 PM
01/14/12 07:52 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Randy I had an opportunity to compare 5 different rods side by side before I chose the K-1 rods When I was checking them before assembly all eight were perfect except one pin bushing was slightly tight.Just a few seconds with some crocus cloth and perfect like the rest.
Give Nick a call I think he has a few sets on the shelf but they may be for 990 pins what size are your pins?
Gus
64 Plymouth Savoy
Dana 60
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: fourgearsavoy] #1156422
01/14/12 09:14 PM
01/14/12 09:14 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Not this..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Eric] #1156423
01/14/12 09:20 PM
01/14/12 09:20 PM
tboomer Online work
tboomer  Online Work
Ouch!! Did ya figure out what to do yet,Eric??
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: tboomer] #1156424
01/14/12 09:25 PM
01/14/12 09:25 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Listen to BGR in the first place and buy better parts ....building a new mill shortly..
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Eric] #1156425
01/14/12 09:27 PM
01/14/12 09:27 PM
tboomer Online work
tboomer  Online Work
Good luck,Eric!!
Re: AFTER-MARKET ROD SUGGESTIONS? [Re: Eric] #1156426
01/14/12 09:34 PM
01/14/12 09:34 PM
P
P
Not this..
Eric, knock it off. how many times to you have to be told those are the best "BANG" for the buck.
(it did go bang, right?)
good luck with the new combo.
