Re: Carb help - what is this?? Pics
[Re: Mass_Mopar]
#115634
09/05/08 05:41 PM
09/05/08 05:41 PM
Posts: 5,867 MA
Mass_Mopar
MA
[Re: Mass_Mopar]
#115635
09/05/08 08:08 PM
09/05/08 08:08 PM
Posts: 1,475 Ontario, Canada
78D150CLUB
My avatar is a self portrait!!
Ontario, Canada
Look like the idle vent valve lever. Opens the bowl to atmosphere at idle to prevent over rich idle. Not an expert on carbs, though.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
[Re: Mass_Mopar]
#115636
09/05/08 08:10 PM
09/05/08 08:10 PM
RapidRobert
That lever either opens or closes(I forget which) the bowl vent when the throttle returns to idle & the bowl vapors come out the large nipple you see which(originally) went to a charcoal canister which absorbed tha vapors & kept them out of the atmosphere. Leave it, the carb needs it to function correctly. & since this bowl vent nipple is outside the air cleaner(unlike a holley) I would consider adding a filter or plumbing it to the inside of the aircleaner so that dirt/debris dont have direct access to the float bowl though many are run open like yours & no problem.
[Re: Mass_Mopar]
#115638
09/05/08 10:07 PM
09/05/08 10:07 PM
RapidRobert
You might take it out which would leave the bowl vent closed all the time & see how it acts. EDIT the top needs to come off to get it out.
