Page 1 of 18 1 2 3 17 18
Coming to a strip near you, 25.5 (70) Challenger #1156159
01/13/12 02:44 PM
01/13/12 02:44 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Been working hard on the Challenger lately. Here are some progress pictures.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156160
01/13/12 02:45 PM
01/13/12 02:45 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Another
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156161
01/13/12 02:46 PM
01/13/12 02:46 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
A Pillars & knee bar.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156162
01/13/12 02:46 PM
01/13/12 02:46 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Chute mount. All behind license plate.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156163
01/13/12 02:48 PM
01/13/12 02:48 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Stock dash back in.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156164
01/13/12 02:50 PM
01/13/12 02:50 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Rear bars behind main hoop.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156165
01/13/12 02:52 PM
01/13/12 02:52 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
down to under car shock bar.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156166
01/13/12 02:54 PM
01/13/12 02:54 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Nice work
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: Tig] #1156167
01/13/12 03:01 PM
01/13/12 03:01 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Thanks. Been alot of hard work the last 3 or 4 weeks so far. Alot more to go.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: Tig] #1156168
01/13/12 03:10 PM
01/13/12 03:10 PM
an8sec70cuda Offline
Nice work
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: an8sec70cuda] #1156169
01/13/12 03:33 PM
01/13/12 03:33 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Thanks Chip.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156170
01/13/12 06:24 PM
01/13/12 06:24 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Nice work
Hope that dash pad was junk b4 you cut it up.....70 dash pads are not cheap
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 340RICK] #1156171
01/13/12 06:32 PM
01/13/12 06:32 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
one thing you may want to look into while still in fabrication stage is the 25.3 spec. the couple extra bars will allow you to cert. to 6.0 instead of the 7.50 with the 25.5. you may never use it but is nice to have if you ever do upgrade down the line. also one mistake i made is checking for clearance on the dash bar (same as yours) the stock cluster will not fit
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156172
01/14/12 12:25 AM
01/14/12 12:25 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Another
What do that bar that connects to the crossmember to the inside frame rail connects to or do it just dead head into the frame?It looks good.............
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: racerx] #1156173
01/14/12 11:20 AM
01/14/12 11:20 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Looks Great!! Moly Tubing?
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 340RICK] #1156174
01/14/12 02:08 PM
01/14/12 02:08 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Nice work
Yep. Dash pad was pretty much junk. Going to get it recovered once everything is fabbed.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1156175
01/14/12 02:09 PM
01/14/12 02:09 PM
tboomer Online work
tboomer  Online Work
Looking good!!
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: prochargedhemi] #1156176
01/14/12 02:14 PM
01/14/12 02:14 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Kind of thought about 25.3 but with my budget it will never go 6's. Going to be using aftermarker gauges. Stock ones are to dang hard to see at night. ecspecially, at high speeds. Would like to do the "All Motor" &/or stock suspension classes, but I have enough NOS to nuke a small town for my 440 build & for future use (2) 106MM turbos for the alum HEMI build. Won't even need the 7.50 cert at first but at least it will be all done right.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: STEFF] #1156177
01/14/12 02:16 PM
01/14/12 02:16 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
All Moly tubing. Very similar to how your old car was done.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: racerx] #1156178
01/14/12 02:22 PM
01/14/12 02:22 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Another
It goes thru the trans cross member part of the frame, then turns & goes thru the other part of the front sub frame & then up on an angle to the inner rocker panels with plates welded to the inner rocker panels. I think I have pictures of that too. I'll look.
