Re: Coming to a strip near you, 25.5 (70) Challenger
[Re: SCATPACK 1]
#2455086
02/21/18 02:25 PM
02/21/18 02:25 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Awe, thanks guys. Yeah, it is taking a lot longer than I expected but they usually do. Hoping for later this season to be out making test hits. (Fingers crossed).
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2455691
02/22/18 04:32 PM
02/22/18 04:32 PM
6PKRTSE
Motor City
Oops, the shaker parts pictures did attach to my edited post above after all. Such a pain to do anymore. I have to go to a website, resize & resave every single picture individually, then I am able post them.
[Re: second 70]
#2456727
02/24/18 04:11 PM
02/24/18 04:11 PM
6PKRTSE
Motor City
Nice subtle mod. No one would even notice that. Looks good.
[Re: 6PKRTSE]
#2476903
04/03/18 05:50 PM
04/03/18 05:50 PM
6PKRTSE
Motor City
I finally got out in the garage to work on the latest project a little. I had to modify & reconfigure my outboard fogger around a little & lean the solenoids in a little to clear & be more inboard. I made all of my templates to start making my dual Dominator tunnel ram shaker conversion Time to start hacking on the parts now.
[Re: HardcoreB]
#2477418
04/04/18 03:24 PM
04/04/18 03:24 PM
6PKRTSE
Motor City
I understand. Most scoops do not pull in anywhere near as much as as most people think they do anyway, unless you are running a legitimate huge ole Pro Stock scoop. This scoop will probably be 3" longer & at least 3-4" taller than a stock shaker scoop when done. The openings will be raised slightly & will also be larger in size. It will pull more air than it looks now. The base will mount with stanchions & feet to mount the intake or upper valve cover studs with some quick pins for ease of removal of the whole assembly for in between round maintenance when needed.
[Re: 6PKRTSE]
#2490997
05/02/18 05:18 PM
05/02/18 05:18 PM
6PKRTSE
Motor City
I know, I know, I am taking too long. Believe me, I wish I had more time & money. Finally got out into the garage a little . Got the scoop, hood and base stretched 3" & fitted all around everything to fit the dual dominators on a tunnel ram, sits nice. Even will still be able to use the seal to seal it all of to the hood. Marked the scoop as it sits now to know how much of it stick thru as it is. Going to stretch the height next and then fiberglass it all back together.
[Re: 6PKRTSE]
#2491474
05/03/18 01:52 PM
05/03/18 01:52 PM
6PKRTSE
Motor City
Thanks guys, I am thinking I may plumb one side of the nostriles to feed air the rear carb & the other side to feed air to the front carb within the bubble.
[Re: 6PKRTSE]
#2491519
05/03/18 03:08 PM
05/03/18 03:08 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Holy smokes...Very nice...enjoying the pics....I'm not worthy....
Rich H.
Esse Quam Videri
[Re: 6PKRTSE]
#2491949
05/04/18 01:21 PM
05/04/18 01:21 PM
6PKRTSE
Motor City
Thanks Zippy. You are worthy. Just get that GTX out to Milan. We need more Mopars out there. I am trying....
[Re: 6PKRTSE]
#2493273
05/07/18 04:56 PM
05/07/18 04:56 PM
6PKRTSE
Motor City
Worked on project Super Shaker a little more this weekend. Time to start fiberglassing it all back together next. Stretched the Nostril openings down slightly to see how it will looking from 2-1/2" tall openings to 4" tall openings. Not pictured but I made some aluminum stanchions that also joined the lower base to the upper bubble to keep the needed spacing & distant correct & everything centered to the hood opening. What is my easiest way to continue from here?
[Re: 6PKRTSE]
#2493275
05/07/18 05:03 PM
05/07/18 05:03 PM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
Can't wait to see this thing finished. Nice work!
[Re: 6PKRTSE]
#2493442
05/08/18 12:16 AM
05/08/18 12:16 AM
6PKRTSE
Motor City
It's still a street car. I am not concerned about every tenth. Besides, I can just spray it harder if needed. Lol. Hard to tell but,the scoop is 3-1/2" above the carbs.I know several people running in the 7's (mid to low 4's in the 1/8) where their cowl induction scoops almost touch the carbs and did not effect performance.
