Page 16 of 18 1 2 14 15 16 17 18
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: SCATPACK 1] #2455086
02/21/18 02:25 PM
02/21/18 02:25 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Awe, thanks guys. Yeah, it is taking a lot longer than I expected but they usually do. Hoping for later this season to be out making test hits. (Fingers crossed).
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2455691
02/22/18 04:32 PM
02/22/18 04:32 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Oops, the shaker parts pictures did attach to my edited post above after all. Such a pain to do anymore. I have to go to a website, resize & resave every single picture individually, then I am able post them.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2456723
02/24/18 04:04 PM
02/24/18 04:04 PM
central il.
second 70 Offline
second 70  Offline
central il.
Jay if you can believe it I even had to modify my shaker because the Msd probillet distributor was too tall. Lol
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: second 70] #2456727
02/24/18 04:11 PM
02/24/18 04:11 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Nice subtle mod. No one would even notice that. Looks good.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2476903
04/03/18 05:50 PM
04/03/18 05:50 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
I finally got out in the garage to work on the latest project a little. I had to modify & reconfigure my outboard fogger around a little & lean the solenoids in a little to clear & be more inboard. I made all of my templates to start making my dual Dominator tunnel ram shaker conversion Time to start hacking on the parts now.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2477003
04/03/18 08:20 PM
04/03/18 08:20 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Love that car!
'63 Dodge 330
11.19 @ 121 mph
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2477343
04/04/18 12:21 PM
04/04/18 12:21 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I'm not paging thru the achieves to see how I have complimented you in the past, just know I really like your work!!! I am of the school of that there are worthwhile sacrifices in performance in the name of style. No doubt the air cleaner mod is one...I just HAVE (LOL) to warn that I don't think that scoop is going to do any favors for the potential of this engine.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: HardcoreB] #2477418
04/04/18 03:24 PM
04/04/18 03:24 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
I understand. Most scoops do not pull in anywhere near as much as as most people think they do anyway, unless you are running a legitimate huge ole Pro Stock scoop. This scoop will probably be 3" longer & at least 3-4" taller than a stock shaker scoop when done.
The openings will be raised slightly & will also be larger in size. It will pull more air than it looks now.
The base will mount with stanchions & feet to mount the intake or upper valve cover studs with some quick pins for ease of removal of the whole assembly for in between round maintenance when needed.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2490997
05/02/18 05:18 PM
05/02/18 05:18 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
I know, I know, I am taking too long. Believe me, I wish I had more time & money. Finally got out into the garage a little . Got the scoop, hood and base stretched 3" & fitted all around everything to fit the dual dominators on a tunnel ram, sits nice. Even will still be able to use the seal to seal it all of to the hood. Marked the scoop as it sits now to know how much of it stick thru as it is. Going to stretch the height next and then fiberglass it all back together.
rsz_20180427_181144_002.jpgrsz_20180501_181237_002.jpgrsz_20180501_190142_002.jpgrsz_20180501_194001_002.jpg
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2491059
05/02/18 07:44 PM
05/02/18 07:44 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Always enjoy your project......GOOD LUCK with it up
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: racerx] #2491472
05/03/18 01:47 PM
05/03/18 01:47 PM
moparx Offline
moparx  Offline
very nice ! up
beer
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2491474
05/03/18 01:52 PM
05/03/18 01:52 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Thanks guys, I am thinking I may plumb one side of the nostriles to feed air the rear carb & the other side to feed air to the front carb within the bubble.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2491519
05/03/18 03:08 PM
05/03/18 03:08 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Holy smokes...Very nice...enjoying the pics....I'm not worthy....
Rich H.
Esse Quam Videri
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2491949
05/04/18 01:21 PM
05/04/18 01:21 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Thanks Zippy. You are worthy. Just get that GTX out to Milan. We need more Mopars out there. I am trying....
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2493273
05/07/18 04:56 PM
05/07/18 04:56 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Worked on project Super Shaker a little more this weekend. Time to start fiberglassing it all back together next. Stretched the Nostril openings down slightly to see how it will looking from 2-1/2" tall openings to 4" tall openings. Not pictured but I made some aluminum stanchions that also joined the lower base to the upper bubble to keep the needed spacing & distant correct & everything centered to the hood opening. What is my easiest way to continue from here?
rsz_20180504_210538.jpgrsz_20180504_205810.jpgrsz_20180504_205810.jpgrsz_20180504_205758.jpg
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2493275
05/07/18 05:03 PM
05/07/18 05:03 PM
an8sec70cuda Offline
Can't wait to see this thing finished. Nice work!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2493335
05/07/18 07:50 PM
05/07/18 07:50 PM
Texas
RustyM Offline
RustyM  Offline
Texas
Is air flow to the carbs going to be an issue with it that tight above carbs- looks really close??
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2493350
05/07/18 08:27 PM
05/07/18 08:27 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
The X275 gen 3 'cuda is on the Radialfest 2018 tee shirts. I can't find a latest pic, but I have one.
http://www.radialfest.com/radial-fest-t-shirt/
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2493419
05/07/18 11:31 PM
05/07/18 11:31 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I will say from testing my stuff the carbs that close to the lid didn't like it at all. Killed it a .10 easy. Does look cool though.
Doug
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2493442
05/08/18 12:16 AM
05/08/18 12:16 AM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
It's still a street car. I am not concerned about every tenth. Besides, I can just spray it harder if needed. Lol. Hard to tell but,the scoop is 3-1/2" above the carbs.I know several people running in the 7's (mid to low 4's in the 1/8) where their cowl induction scoops almost touch the carbs and did not effect performance.
