Re: Valve Spring Pressure
[Re: turbobitt]
#1155697
01/13/12 01:28 PM
01/13/12 01:28 PM
Posts: 3,456 Out West
408strokerdart
Out West
I will be installing some new heads and a roller cam in my race car for the 2012 season. The cam has a duration of 308 @ .020 and .704 lift at the valve with 1.6 rockers. The motor will not go over 7500 RPM. What is a good conservative seat pressure to use?
Not enough information. The lift and duration don't tell you much. the type of ramp profile would be more helpful.
Allan G.
Also, what size and material valve?
[Re: reknapp52]
#1155702
01/15/12 09:35 AM
01/15/12 09:35 AM
Posts: 2,091 Delray beach, Florida
Performance Only
HI-TORQUE .440" ROLLERS These designs are very aggressive and can be used with a variety of rocker ratios. Smaller designs work well in oval track motors and larger designs work in drag racing applications. The Hi-Torque .440” designs are stable to 8200+ rpm.
8200+ rpm. LOBE RATED DURATION IN LOBE TAPPET LIFT @ THEORETICAL VALVE LIFT NUMBER DURATION DEGREES LIFT TDC @ “0” LASH ROCKER ARM RATIO CAMSHAFT TYPE @ .050” @ .200” 106° 110° 1.5 1.6 1.7 4217 278-8 250 174 .440 .115 .099 .660 .704 .748 4216 280-8 252 176 .440 .119 .102 .660 .704 .748 4240 284-8 256 178 .440 .122 .105 .660 .704 .748 4241 288-8 260 182 .440 .131 .114 .660 .704 .748 4243 292-8 264 186 .440 .140 .123 .660 .704 .748 4245 296-8 268 190 .440 .149 .131 .660 .704 .748 4252 300-8 272 194 .440 .157 .139 .660 .704 .748 4253 304-8 276 197 .440 .177 .160 .660 .704 .748 4213 308-8 280 201 .440 .185 .167 .660 .704 .748
4214 312-8 284 205 .440 .191 .174 .660 .704 .748 4254 316-8 288 210 .440 .198 .180 .660 .704 .748
machine shop owner and engine builder
[Re: Performance Only]
#1155703
01/15/12 10:46 AM
01/15/12 10:46 AM
Posts: 16,928 NC
440Jim
NC
Good info for evaluating the cam. Lobe intensity from 0.020" to 0.050" is 308-280=28 Lobe intensity from 0.050" to 0.200" is 280-201=79 It does goes easy near max as it limits lift to .440" So the quick action initially matches the description "high torque"
[Re: 440Jim]
#1155705
01/15/12 11:17 AM
01/15/12 11:17 AM
Posts: 4,315 Prospect, PA
BSB67
Prospect, PA
Jim - If you have not done so, you should graph the advertised, 0.050, and 0.200 numbers for lobes-of-interest. It is clear that you would appreciate this. It paints a very clear picture of the agressiveness of the lobes, and is a great way of making the comparisons between different lobes, as the slope of the line is the rate. I've done this for most of the comp lobes from the realitvely slow -5 to the TKs, and some other bands as well. I did it by hand on 11x17 in multiple colors.
Let me know and I'll send you what I have if you're interested.
[Re: BSB67]
#1155706
01/15/12 12:35 PM
01/15/12 12:35 PM
Posts: 16,928 NC
440Jim
NC
Do you mean like the attached? I all those lobes are of the same family, so they look similar in slope/intensity below 0.200". I will make another comparison with a lobe from another family.
I still think 275-280 seat and 700 lbs over the nose will get the job done
Dan, I don't know the right spring pressures. But what you are saying sounds like plenty to me for that cam. Some guys are running 0.660" rollers with only 220ish on the seat. But I am thinking the lobe intensity from 0.020" to 0.050" would be a factor in the seat pressure. And this is more agressive in that range than some other 0.660" rollers. And rpm limit is a key factor as you pointed out.
[Re: 440Jim]
#1155707
01/15/12 01:04 PM
01/15/12 01:04 PM
BSB67
Prospect, PA
Not exactly. I use the change of cam shaft degrees (technically crank) on one axis, not actual degrees. This way the size of the cam does not effect the comparison - it is strictly compares the lobe rate. Said differently, all of the RT lobes irrespective of the duration will draw the exact same line.
Also, in the electronic spreadsheets that I used did not work well for me when comparing similar lobe rates, specifically, the NC vs HT406 vs the RX, or the RC vs HT440 vs RT as they end up on top of one another. The fine lines on a large page really make a difference for me.
[Re: BSB67]
#1155711
01/15/12 01:27 PM
01/15/12 01:27 PM
Posts: 16,928 NC
440Jim
NC
OK, that is the intensity I was talking about. Time to replot... see attached. The y-axis (vertical/side) is the duration change from 0.020-0.050" plotted at the 0.050" position on the x-axis (bottom)
