360 heads #1155228
01/12/12 01:59 PM
01/12/12 01:59 PM
meadville, pa
chargerbill Offline OP
meadville, pa
what year did they start putting harden seats in the heads for unleaded gas
Re: 360 heads [Re: chargerbill] #1155229
01/12/12 02:19 PM
01/12/12 02:19 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Think it was 72 or 73 ??? If not, then for sure it was 74 . . .
Re: 360 heads [Re: a12rag] #1155230
01/12/12 03:04 PM
01/12/12 03:04 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
You won't see it as they were induction hardened not inserts.
Re: 360 heads [Re: MoparforLife] #1155231
01/12/12 05:31 PM
01/12/12 05:31 PM
dogdays Offline
dogdays  Offline
True, my '73 400 had induction hardened seats, only could tell by the blue color on the casting after hot-tanking.
R.
Re: 360 heads [Re: chargerbill] #1155232
01/14/12 12:06 PM
01/14/12 12:06 PM
meadville, pa
meadville, pa
thank you everyone i have a set of 73 360 heads and was just wondering so how do i know if mind are or aren't
Re: 360 heads [Re: chargerbill] #1155233
01/14/12 02:13 PM
01/14/12 02:13 PM
Upper Midwest
Upper Midwest
Personally I wouldn't worry about it. In our experience the Mopar heads can take more UL gas usage with no damage that either of the brand x heads. This especially so under the minimal mileage and light load usage most of these engines will be subjected too. If the valves need re-seating any way then have a set of hard seats installed on the exhaust valves.
