sonic test a rb block? #1154774
01/11/12 03:49 PM
01/11/12 03:49 PM
charlotte nc
jimmysarrow Offline OP
charlotte nc
What are the sonic test numbers a block should have? I am looking at a 440 with 55 over pistons.
Re: sonic test a rb block? [Re: jimmysarrow] #1154775
01/11/12 04:57 PM
01/11/12 04:57 PM
Idaho
LaRoy Engines Offline
Idaho
The numbers are subjective depending upon the ultimate purpose. Which is? And what numbers do you have?
Re: sonic test a rb block? [Re: jimmysarrow] #1154776
01/11/12 05:01 PM
01/11/12 05:01 PM
AndyF Offline
AndyF  Offline
If you can keep all the numbers above .125 after boring then you're lucky. Ma Mopar didn't know much about quality control in the 70's. Most blocks have at least one thin hole, sometimes two are thin.
Re: sonic test a rb block? [Re: AndyF] #1154777
01/11/12 05:09 PM
01/11/12 05:09 PM
charlotte nc
charlotte nc
Andy , what numbers do you usually see when you are looking at a block before you bore? I am going to sonic check some blocks this weekend just looking for a number that is a go no go.
Re: sonic test a rb block? [Re: jimmysarrow] #1154778
01/11/12 05:27 PM
01/11/12 05:27 PM
Idaho
Idaho
Your other post indicates you intend to race with this block. Look for a block that is at least .200" on the major thrust sides. I recently checked 11 blocks before I found two like that. The thinnest piston pin sides in those blocks were .147" and .163", thinner than I wished for but acceptable.
Re: sonic test a rb block? [Re: LaRoy Engines] #1154779
01/11/12 08:09 PM
01/11/12 08:09 PM
AndyF Offline
AndyF  Offline
It is hard to find a block with all major thrust sides greater than 0.200. Maybe 1 in 10 would be that thick. Most people don't have 10 blocks to pick from!
Re: sonic test a rb block? [Re: AndyF] #1154780
01/11/12 08:16 PM
01/11/12 08:16 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If we find .180 at the thrust side at finish bore we consider it to be a great block.
Re: sonic test a rb block? [Re: B G Racing] #1154781
01/11/12 09:24 PM
01/11/12 09:24 PM
Idaho
Idaho
AndF & B G Racing, true and true.
Re: sonic test a rb block? [Re: LaRoy Engines] #1154782
01/12/12 01:47 PM
01/12/12 01:47 PM
dogdays Offline
dogdays  Offline
So unless you have a mountain of blocks plan on sleeving at least one hole.
R.
